STOCK K/B SS VS STOCK O.S. 0.21 OUTBOARD!
#51
RE: STOCK K/B SS VS STOCK O.S. 0.21 OUTBOARD!
Wasn't it Tommy Lee that held the IMPBA B tunnel SAW record with a modified Hot Shot Sprint that was over 60 mph and held that record for many many years?
#53
Thought it was around 62mph and was there for over 10 years.. Believe Kensil now has the boat. When we were talking, Bob mentioned the boat weighed nearly 6.5 lbs.. And I did look at IMBPA, Tommy still holds the D, E and F OB records for SAW, all from 97 or 99.
#54
Run 5 or 6 tanks of fuel through your O.S. before removing the head shim. Here's my VS1 setup:
1. 3 oz of lead attached to the front of the radio box.
2. C/L of prop 3/16" above the bottom of the sponsons.
3. Just a slight amount of down thrust on the prop.
4. 50% O'Donnell Boat Fuel.
JD
JD
