Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
crac\ked hull
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
crac\ked hull
Old 01-20-2010, 06:04 PM
R.Chando
Default crac\ked hull
as with most boats these days mine is made of plastic is there any way to repair a plastic hull,or is there another way to get a hull as they dont have them I belive it atraxx 31 , is there a hull that I could make and add the hardware into it
Old 01-21-2010, 12:00 AM
Ron Olson
Ron Olson's Avatar
Default RE: crac\ked hull
Would that happen to be a LaTrax? That was the predecessor of Traxxas.
OK, how bad is it? If it is made from ABS plastic it isn't too bad to fix a crack. You can either use CA glue or PVC pipe cement to repair it. Holes aren't that bad to fix either as I did one that should have been toast.
Old 01-21-2010, 12:12 AM
zippkitrunner
i have used gorilla glue and vinyl screen if you can get to theback side of the crack. it acts like a fiberglass patch and the screen give it strength
