Aeromarine cat 18
#76
NY
RE: Aeromarine cat 18
The Z strut has been replaced with the ORIGINAL strut. You heard it here first. [&o]The myth busters Have proven it as a bust. The CMB zoom carb is dead in the water. I have the Picco P5 with a OPS slide carb, using a bellcrank.I also need more air movement,that big old Cooper pipe is large & hot .I will open up the cover some more.
#78
NY
My Picco P5 had a Teflon liner for the OPS carb. It would spit it out after a few revs The liner is on the radio box The outher option was to drill a hole into the case and add a screw on each side of the carb. I found a OPS engine that has the smaller dia carb ,no liner In my box of goodies
#79
FL
Clean all surfaces good with brake parts cleaner, scuff both sides of the liner with 400 grit or so, clean again, then Silicone it in with a Light coat on each side of the liner,, Let it dry Over Night. I had a similar issue using the OS carb on the Go Engines and a brass bushing. Worked like a champ..
#80
NY
Will do buddy, I tossed the cooper quiet pipe for a old prather pipe. I have all kinds of room now ,back to the Picco P5 which is a very good engine. You do need to toss the picco carb ,too small a intake. When I put the large bore carb on, she screams. I also looked a a K&B black carb too small a intake also K& B sells the Kelvin carb with a large bore
#81
NY
My latest revision of the MM18 ,I put that Cooper QT pipe on the shelf ,Amax It's the Picco P5 ,now I'm happy Except for a prop ,still looking in my prop box
#83
NY
TT it's usually the inside sponson that I like to clip a float with. I sent a e-mail to Joe I already used my spare. 3 rd set this year. LOL I feel lucky so far ,care must be given to the parallel sponsons when reattachment.
