Central NEW YORK boaters
#1326
RE: Central NEW YORK boaters
ORIGINAL: Canadian LoCo
WOW great work guys the pond has no ice holy.
well with all that hard work you will be able to have a great and fun place to run your boats
does look like alot of work I would be tired my self just looking at the pic's Im tired LOL.
Neil nice Mono hull you have there should be fun to drive this up comming season.
Regards
Luc W.
Regards
Luc W.
Part of the pond has real thin ice still. A big gas mono could proabably break through.... We are getting real warm weather down here, but I notice you don't have to go that far north before it gets colder. There was a big snowmobile race that was post poned at the Finger Lakes Race Track. They tried making snow, but they just could not make enough.
#1327
ORIGINAL: Hydro Junkie
I've noticed the silence as well. Seems like the only threads that are getting any action are this one, the Circus build and my Pak thread, though the Pak thread is mostly non-Pak conversations lately. I guess I need to get the Paks all done and start a new thread on building the Executone so people can see there isn't really that much difference between the sport 20, 40 and scale hulls other than size
Side note, I ran into a stumbling block with the digital timers for the timing system. These timers are used for many applications, and I'm having trouble setting it up to work like a stop watch. I logged onto a automation forum so hopefully I'll get some help. I'll e-mail tech support too.
#1329
ORIGINAL: advanced builder
my Grandson Frank
my Grandson Frank
#1331
ORIGINAL: engineman351
Craig...wow you guys moved a 'TON' of dirt (more like 2.5 tons!!). Great job. Roger
#1332
PA
Man, you guys did a lot of hard work. After looking at the before and after pics - I was tired.
That is a nice looking mono. Where are you setting the C/G? 32%, 32.5%? Geezer wheels are nice but it just means more to carry to the hot pits. To each his own.........
I really hope IMPBA gets the rule book updated before the season starts. What kind of power is Bob thinking about for the 55" mono? I was concerned about moving from 45" to 51" monos due to the extra weight.
#1333
Bill, I have heard great things about the Microburst monos! Should be hard to beat. I'm no expert, but at some point going longer will only increase performance in really rough water. 51" might be a good sweet spot. The gas Seaducers are 47" if I remeber correctly and allot of the AC Model hulls are about the same.
#1334
NY
55" won't fit into my Santa Fe sideways ,I'll need that trailer .The only problem with that Aeromarine hull is the pipe length is set ,with that funky header. got a S in it. I can't get down to the length I want.
Bill is your hull a microBURST or a MICROBURST. the first on is a Marine Specialties hull .I got one from Sue with a .67 CMB inside. A nice looking hull built by Fred Rodas. The 32% is what I like for CoG
#1335
PA
When you say S bend, does that mean a wrap to center RTC pipe? Don Hollys on Jim's is making hot pipes to order and may be able to help you out. Nowadays I am pretty much running only hotpipes and use the Gizmo Victory pipe if I want more volume.
Dave Showers bought the Microburst molds and has been making them for some time. Mine is not a Marine Specialties hull. I was running an AC Lazer (45") and it handled well in rough water since the beam was 1" wider.
#1337
Hi Guys,
I'm running an aeromarine vector mono this season, modded 260.
Looks like I'll definitely run Sport Hydro, Rigger and Mono gas classes along with my .18 nitro rigger. If I get a little more organized in my pit area 3 or 4 classes should not be a problem, last year 2 to 3 was the max.
Bob
Oh Darn.... There goes my low post count
Bob
#1338
Update on Timing System....
I think I figured out what I was doing wrong with the timer. First, the timer runs with a constant input. Pulling the input stops the timer. I had assumed a input would start it and another input would stop the timer. The second is that the timer comes from the factory set for negative logic. The input is switched with a ground not a 12v positive. So, it looks like I'm back in business... I do need to rewire the relays a little, but so far I see no problems.
#1339
NY
ORIGINAL: Blackout
#1340
I 'm glad you don't need my help
Bob I thought you were running a Apache !
ORIGINAL: Blackout
A Vector.... Is that an air intake on the front deck?
#1341
Looks like it Craig I would not want that on my boat just a good place
for water to come in a fill up your boat.
great looking paint job on them 4 sure.
Regards
Luc W.
Regards
Luc W.
#1344
ORIGINAL: Joe Petro
Craig,
If you need any electronics help, especially analog logic, let me know...
Joe
Craig,
Joe
I heard Zippkits is sponsoring a SAW event in Alabama this spring! Are you going?
#1345
NY
Craig, Can you send me the steps for gettig pics into a post like you did for the 'Vector'? I have some .jpg's in MyPictures I'd like to add. Thanks, Roger
#1346
Hello Roger Im not to sure what Craig uses but I use this http://photobucket.com/
you just need to sign up then upload all the pic's you want even video's if you wish.
very easy to use after you up loaded your pic's you will see a little drop down on the pic you
would like to post just click on the last one IMG code and it will copy then just past it in your post on here.
hope this helps
Regards
Luc
hope this helps
Regards
Luc
#1349
He's working way to hard on that Zipp hull. My only two questions are does it float and does it run
#1350
All I did was copy the properties from the Aeromarine site by right clicking onto the picture and clicking on properties. Then just paste the properties between the image quotes that pops up when you click on the image icon when you reply to a message.
