Hots Plans
http://www.rcstore.com/rs/general/li...d=36&catego=PL
this is a link to the sport plane plans on the model airplane news site. its called "the hots" a little ways down.
hey guys i am building the hot hots from scratch and would like the construction article for it but cant seem to get my hands on the january 2002 issue of rcm does anyone have it photocopied or can point me in the right direction without having to subscribe thanks again and good bless
derrick brunson
[email protected]
derrick brunson
[email protected]
![](/forum/images/badges/premium_member.png)
The Hot Hots has a detachable wing as well as a fuselage extended to a 'cowling' type front.
The stated weight is 3lbs 6 oz. Has anyone built one at anything like this weight?
KDC
Be careful on the tail section. I built two of these and they will build tail heavy if you don't take a few measures to lighten the tail. The plane flies great! I crashed my first one due to dumb thumbs but, I liked the plane so much I built a second one. I did modify the second one by building the rudder and elevator with counter balance tabs. The plane will knife edge great, even without the counterbalance tabs.
I'm not sure about the accuracy of my scale but I think it weighed 6 and a half pounds. I'm going to get a new set of digital fish scales and weigh it again sometime. The plane flies great," in fact, it is my favorite 40 size plane," but I plan to build another and take extensive use of lightening techniques that I have learned in the last year or so. This plane as weighed was equipped with 4 645mg hytec servos 1 hs81 throttle servo, a 5 cell 1850 mah battery, pull-pull on the rudder, Magnum 52 2c engine, and a Sullivan tail wheel assy. Also, model is covered in Ultracoat. I'll try to get some pics next weekend and post them.
Surely it cannot be 6 and a half pounds! The article says 3 lb 6 oz (54 oz) which is almost half your models weight. Frankly I expect one could build to 4 and a half pounds without too much trouble. With some care I would think 4 lbs and a few ounces would be possible. 3 lb 6oz seems far too low.
I find it is interesting to weigh the model at various stages and particularly before and after painting / fuel proofing.
Buy a digital kitchen scale (out of the household budget!) and weigh a complete model by standing it on a box. Before you put the model on the box, zero the scale to allow for the box weight.
