Go Back  RCU Forums > RC Universe Support > Suggestions
 Ability to edit your posts? >
Suggestions Have a suggestion for a feature, new category or anything else? Let us know by posting it here!
Old 12-20-2004 | 07:19 PM
Default Ability to edit your posts?
What happened with the edit function for posts to threads? I would like to modify/edit and the ability is no longer there? Specific post: http://www.rcuniverse.com/forum/fb.asp?m=2362661
Edit function shows on this post to suggestions will go back and check referenced post again. Confused.
Old 12-23-2004 | 01:47 PM
Banned
Default RE: Ability to edit your posts?
after a certain time has elapsed the ability to edit is removed. it is assumed that after a few months there should be little reason to edit posts. Most of the time the reasons if they exist are bad ones (i.e. covering tracks) while in other cases they are quite innocent intentioned (like an update). If you need an edit beyond the cutoff report the post to a moderator and include what you want changed. They can modify the post for you if there is good reason.
Old 01-03-2005 | 01:34 PM
WORNBOOTS's Avatar
My Feedback: (33)
Marc
I'm not sure what you mean by cut-off period, you mentioned a few months?
I posted this reply (see date)
**RE: OK>> WHAT DID YOU GUYS GET FOR CHRISTMAS!!!!!!! 12/27/2004 11:16:51 PM**
And as I read this thread I checked it and I dont see any edit button. not that I want to edit it but it was a fairly recent post.
By chance did the cut-off period get shortened??
