Dynam 450 erazor CF or B version
Hello
newbie here , is there anybody out there that can tell me where to buy Dynam E-Razor 450 B version or Carbon Fiberversion,white main gear as they are differant to the plastic bodyone , have tried one or 7 and they just stripp , any help would be fantastic , driving me nuts as it was a really nice heli to fly while i was fying it ,but somtimes we crash and i stripped the main wheelwhich was whiteand have not been able to obtain another whiteone and the black ones just strip as soon as you start whizzing it up...........someone please help
cheers
RE: Dynam 450 erazor CF or B version
If your main gear is stripping, check your mesh between your motor pinion and your main gear. Should be loose enough for you to put a very thin piece of paper through it.
Hi
thank you for your promt reply
yep Ive been there and tried several clearances ,tight,loose,rolly paper thickness, I just need that dam white main gear ,have also tried a pinion and main gear from the same supplier ,there is just some difference with the CF chassis somewhere
cheers
cheers
