T-Rex heli For all you T-Rex lovers out there, this where you can post!
Mounting HS 56s
Old 03-04-2006 | 08:51 PM
Default Mounting HS 56s
I am building a T-Rex 450XL CCPM with Hitec HS-56HB servos for the front end. When mounted normally the servos arms hit the canopy. Is there a special way to mount them such as inside the frame rather than on the outside?
If anyone has a picture of these servos mounted, I would sure like to see it.
Old 03-05-2006 | 02:50 PM
chris b's Avatar
Default RE: Mounting HS 56s
Hey elhepilot, I have a couple here. Let me know if you need more detail.
Chris B
http://www.rcuniverse.com/forum/fb.asp?m=3981597
Old 03-05-2006 | 03:10 PM
Thanks - looks like its a lot easier in the SE.
Old 03-06-2006 | 08:49 PM
I too am using the hs56 and had a clearance problem. I made a small thin spacer (a little less than one eight inch) out of light ply. I epoxyed it to the top of the servo mount tab. I mounted the servos from the inside. The servos feel rock solid in the frame. I also had to stretch the canopy a little bit. I carefully folded several paper towels and neatly laid them across the top of the frame and over the affected area. Then took a hair dryer and carefully heated the area. It doesnt take much heat at all. This somewhat reformed the canopy and I now have an extra half inch of clearance. The plastic windshield may be a little trickey to fit now but am sure it can be done. Good luck..........................
Old 03-06-2006 | 09:24 PM
Thanks for your reply.
