Now what!!! Newbie
CA
Now what!!! Newbie
If it's not one thing it's another. First off I'm new to this hobby and have built and setup the heli with no support. Which has caused me a vast amount of FRUSTRATION!! I followed the Finless videos which were awesome. First flight she hovered nice but I was getting glitches in the servos. With my lack of experience and to much negative pitch at the zero positon I got panicky after a bad glitch and slammed her hard into the ground. Well I replaced the boom and thanks to everyone on these forums fixed the glitch problem (Antenna routining) and learned about pitch curves for use new guys. Well just took her out and hovered it until the battery got low. I was so happy with myself and bragged to the wife. I went to fly the heli later and now the servos just buzz and gyro blinks. There is no response to the control inputs. What did I do Now?!! Did I fry something unknowingly?
Trex 450XL
430L 3550KV Brushless Motor
35amp align ESC
15c 1500mah LIPO
Trex 450XL
35amp align ESC
15c 1500mah LIPO
RE: Now what!!! Newbie
Did you re-charge the battery?
Sorry to sound dumb, but the cutoff voltage on speed controls to protect your lipo from over discharge is calculated when you first turn it on. If the battery is not fully charged when you first start then it can still be over discharged, even with "protection".
I mention this because you said you "just took her out and hovered it until the battery got low" after you'd repaired it. So I assume the battery was still half charged after your crash..
Lipo batterys are very sensitive to over discharge. I know, I've killed one. (and also to over charging)
Karyn
Karyn
VA
I'd look into a low battery. The symptoms you describe can be the result of a dead battery.
You might also considering checking into finding some local help. There are heli pilots in San Diego.
[link]http://www.pilotlocator.net/index.php[/link]
CA
Thanks guys, But it's a transmitter. I decided to switch over to my plane and nothing. Bad thing is I can't find my receipt to get the warranty work done. The darn thing is only like 3 months old too. I hope Hitec is has reasonable rates.
ON, CANADA
ORIGINAL: slbledsoe
VA
Contact the verndor where you purchased the Tx and see if they can provide you with a copy of the receipt. My LHS can do this as they keep a list in their computer system of all my purchases.
