T-Rex heli For all you T-Rex lovers out there, this where you can post!
Seesaw
Old 01-25-2007 | 12:21 PM
Default Seesaw
Anyone have any problems with their seesaw being tight causing the flybar not being able to return to center? I resized all my ball links and for some reason my seesaw is tight, just wondering if anyone else knew the problem before I take my head apart.
Old 01-27-2007 | 01:10 AM
samtech's Avatar
Default RE: Seesaw
Try loosening the screws that hold the seesaw on to the head. I've done the same thing having the head taken apart. If that doesn't work take a look at how all your links are adjusted. Hope it helps.
Old 01-28-2007 | 02:27 PM
Default RE: Seesaw
I had the same problem. links are to tight squeeze them a little with pliers till the can rotate on there own weight. also the little washer on the upper arm needs to be smooth side on the bearing.
