Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 trex600 setup help >
trex600 setup help
T-Rex heli For all you T-Rex lovers out there, this where you can post!
trex600 setup help
Old 04-01-2007 | 04:35 PM
Default trex600 setup help
well guys,i have everything put together on my heli but when i give it throttle,only one main blade is moving and my flybar moves to the right as well and not just a bit.Is this because something is binding? Also, my 9254 on my tail seems to go forward a tiny bit but goes all the way back and sounds like its forcing.I wish there would be someone around here who could help but no one around here is in to helis and i can't even bring it to a hobby shop for them to check it out because everything is at least 8 hours away from me or more.
Old 04-03-2007 | 09:23 PM
Default RE: trex600 setup help
only 1/2 (one blade) of the head turns when you throttle up?
Old 04-04-2007 | 01:10 AM
LOL - How could that be possible????? [X(]
Old 04-04-2007 | 07:27 AM
Are you saying only one blade is pitching when you apply throttle? It sounds like you're missing a link somewhere, so you're only activating one mixer arm which is why the flybar is pitching oddly and only one blade is getting pitched. Go over the build directions again very carefully. And make sure you have every control rod on. I just finished my build on my 600, and built my 450 about a month ago, and it's very easy to overlook a control rod if this is your 1st build.
As far as your tail servo, you may have your End Point Adj (EPA) in your radio set-up wrong, which may be causing you to lose throw in one direction, and overthrow the servo in the other direction. Check the menu in your radio, and make sure your EPA's are set at 100 for initial setup, and then adjust from there.
Check this link out: http://helifreak.com/viewtopic.php?t=15009. You'll have to register for the site, but this guy finless has videos that basically walk you thru every step of the build and setup process.
Lemme know what you find out.
Chad
