T-Rex heli For all you T-Rex lovers out there, this where you can post!
crashed ***?
Old 01-20-2008 | 11:26 PM
Default RE: crashed ****?
You just simply yank out that little aluminum drum that rests on top of the belt, screw it back together;that's all.
People here are pretty divided on lubing the belt; I'm a little scared to and I'm not having any problems since taking off the idler drum, I don't want to jinx it.
Kinda a b#%^ to replace the belt! I wonder how long they are supposed to last, anyway.
Gary
Old 01-20-2008 | 11:30 PM
i lubed it, i noticed it was smoother, and later on it got more loose i think, what exactly does the belt mod do? its covered on that video?
Old 01-20-2008 | 11:41 PM
ORIGINAL: butters149
ok i will show the LHS the video of the tail mod tomorrow haha, is this only for the SE V2 metal tail or can it be done on the plastic 450S tail also?
Can what be done?
Old 01-20-2008 | 11:46 PM
He grinds off some of the upstop for the rear rotor, that's all. The problem has been rectified at the factory since then with the Version 2, if I recollect right. It hasn't anything to do with the belt.
Old 01-20-2008 | 11:52 PM
Why are you guys grinding stuff? LOL
The idler pulley is not the problem. The plastic SA tail case has many issues. Correct belt tension is also important. The tail boom does move slightly from vibration so use a small amount of thin CA to hold it. A slight twist of the boom will break it loose for maint. or repair.
Old 01-20-2008 | 11:55 PM
  #31
J-MICHAEL's Avatar
ORIGINAL: goldslinger
Gary
Gary--
Do you have a pic of the little aluminum drum your talking about ? I haven't had to much time to research on here about my Trex, still down here in Cali by Pismo beach area and is sucking my time up working...! But I haven't had any tail issues yet, but in case, or even for some prevenative measures, I would like to know about the mod or removal of this piece, just don't understand... I don't want to go taking the wrong thing apart...Lol.. Can you still believe I've only burned 16 packs through it ?!! It's been about two months ! Still new..LMAO !
-- Jeff
  #32
where should i CA it? the tail case or the boom to the frame?
Old 01-21-2008 | 12:00 AM
  #33
A few drops where the boom meets the frame block.
Old 01-21-2008 | 04:45 PM
  #34
BryFlyGuy67's Avatar
nevermind, the LHS put the heli back together, he told me that my back servo ds285 burned out, the elevator one, i wonder how it burned out? maybe that caused my heli to crash.
I originally flew the Spektrum DS285's on my TREX. After crash #4, two of them stripped gears and I replaced them with HS-65MG's. On the advice of several forum members, I ordered metal gear replacements. One of these days, I'll get around to fixing them.
Old 01-21-2008 | 05:00 PM
  #35
Check the tail drive pulley & gear. This also happened to me however I was fortunate to get back on the ground before anything was damaged. The gear may look fine but until you take it out of its case you cant be sure. a lot of work for a little gear but better safe than broke.
