T-Rex 600 set up
Hey guys, I'm looking for different opinions on how to set up a T-Rex 600. I have seen the videos on Helifreak, but I'm reaching out for more opinions on just your basic normal flight. I would appreciate any advice that you guys could give me. Like I said, I'm looking for different set ups and different opinions. Thank you.
CA
Here is my 600 setup.
Scorpion HK-4025 890kv Outrunner Motor
Castle Creations Phoenix HV-85 esc
Outrage 25C 8S 3700mah lipos
Align 6A Linear Regulator w/ Align 2S 1900 lipo
Futaba S9252 on the cyclic
Logictech 6100t Gyro with 6100g servo
Spektrum AR7000 recevier
600mm VBlades
Torque Tube Tail
Align Carbon Tail Blades
I fly with the headspeed governed at 2150rpm. I am not sure what you mean by "basic normal flight". I am just a sport flyer with some inverted circuits attempting to learn some 3D moves.
One of my flying buddies uses the stock 600xl, Align 75A esc, Align 3A bec, Futaba 9351 servos and a Gy611 with a 9256. He is able to throw it around pretty well.
Hope this helps a little.
Brandon
600mm VBlades
Torque Tube Tail
Brandon
Hey Brandon thanks for the response. I guess I should have gotten into more details of the specs. This is what I'm working with.
RCE-BL100G Brushless ESC
6A External BEC w/5.1V Two-way
RCM-Bl650L Motor
401 Gyro
HS-7966HB Coreless Digital Tail Servo
3 servos, Digital Std HD, HS6756HB
7 channel receiver, Spectrum DX7
I guess what I'm seeking help on is the dial up set ups on the DX7. I'm looking for as much information that's working for others that might work for me. I'm looking for reference as a guideline. As for the normal flight, the 600, of course, just to hover and do figure eights. Down the line I would like to progress to 3D. Once again, any help would be appreciated.
RCM-Bl650L Motor
401 Gyro
