Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Small Engine Dyno?
Old 09-11-2004 | 08:18 PM
WS
Default Small Engine Dyno?
Has anyone ever used or built a small engine Dyno? I'd like to somehow get my hands on one or make one in order to test engines for power and torque. Are there any plans available?
Old 09-14-2004 | 07:18 AM
Hobbsy's Avatar
My Feedback: (102)
Default RE: Small Engine Dyno?
American Hobby Products
Old 11-03-2004 | 04:33 PM
MikeSell's Avatar
The AHP Dyna torque is a well tested stand. The dyno only reports engine performance. I have the Dyna thrust which reports the thrust of an engine/prop combination. With a set of test props you can use it to test the power of one engine against another as well as one prop against another. Both retail under
$140. plus shipping. They are not on the net. Look for ads in Flying Models and RC Report magazine.
Old 01-22-2006 | 02:29 AM
w8ye's Avatar
My Feedback: (16)
What about this electric job?
Old 01-22-2006 | 10:44 AM
Found this link that may be of interest:
http://www.aalmps.com/dyno.html
Old 01-23-2006 | 08:04 AM
Hobbsy's Avatar
My Feedback: (102)
The American Hobby Products Torque Reaction Dynamometer
Old 11-09-2006 | 02:35 PM
ORIGINAL: w8ye
Does anyone have any links to the origin of this dyno setup? (re picture in post #4).
Old 11-10-2006 | 09:10 AM
I just built a dyno of my own design using parts and materials I had on hand. I used a Tower engine test stand bolted near one end of a 1" aluminum channel 18" long. I drilled a hole thru the channel for a 1/4" bolt to act as a pivot right under the engine. The pivot swings on a base mounted to the bench. A bolt attached near the other end of the arm serves as a leg that applies the force required to balance the torque generated by the spinning prop. The distance from the pivot to the bolt pushing on the scale is 10". The bolt rests on a digital postal scale. The force on the scale times the distance from the pivot point to the bolt pushing on the scale is the torque. The scale is pretty accurate and automatically zeros out any load acting on it when turned on. So the torque arm can have a load due to the setup not being perfect and the torque will still be accurate. The other source of error is engine rpm. I have a TNC tach so that is covered.
A 1 hp engine turning 10,000 rpm generates 0.5 ft lbs of torque. So typical glow engines will produce loads on the scale in the range of 4 to 30 ozs, right in the working range of my scale.
I have only run the stand briefly and am working on some problems. The engine load is not steady and produces a vibration in the arm pushing on the scale . I am trying to damp this by putting a slab of foam on the surface of the scale. I need to velcro down some things that keep sliding around but the whole works looks feasible so far.
I will get some pictures if there is any interest.
I ran my OS 50 at about full throttle and got roughly 80 ounce inches of torque at 12,000 rpm for about 1.2 hp.
Old 11-10-2006 | 02:01 PM
A pic ------
Old 04-18-2007 | 12:31 PM
ORIGINAL: w8ye
What about it.....Have any plans for that thing?
Old 06-16-2012 | 01:00 PM
ORIGINAL: w8ye
Your electric dyno design looks very well done! Can you tell us about that dynamometer (DC motor w/separately excited field winding) or whatever it is you're using? Please help us understand what you've created by explaining the principles of your design? Where did you get that dc motor/dynamo from? Maybe, porvide us with a link or datasheet and manufacturer? I'm hoping to build one to characterize small dc motors like the motor inside the Hitec HS-6635HB servo, the Mabuchi RF-120CH. Any advice you can provide is greatly appreciated.
Thanks in advance.
Old 06-20-2012 | 02:14 PM
soarrich's Avatar
My Feedback: (98)
I have one of the The American Hobby Products Torque Reaction Dynamometer in a box around here somewhere, $60 plus shipping. It's heavy though, think solid block of wood about 5"x5"x12", it's made of very high quality ply.
