Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Os 46 Fx
Old 10-21-2002 | 11:30 AM
Default Os 46 Fx
Homebrew 6%, 18% aerosave, stock muffler w. deflector, modified 12,25x3,75 apc = 14200rpm.
Old 10-23-2002 | 01:53 AM
Default Os 46 Fx
Hello,
What mod did ya do on the 12.25x3.75 prop?
Thanks.
Regards
Marcus
Old 10-24-2002 | 05:50 AM
Default Os 46 Fx
I took 5mm off the tips with my starter battery...
Old 11-04-2002 | 09:30 PM
Default Os 46 Fx
Huh ?!?!?! With the starter battery?
Old 11-05-2002 | 10:39 AM
Default Os 46 Fx
Yes!
From now on I shut off the engine at the runway and carry the plane to the pits!!!
Old 11-05-2002 | 04:20 PM
Default Os 46 Fx
Ohhhhhh. This was one of those unplanned field modifications; aka a screwup. Do you recommend this mod for 12.25x3.75 props?
Old 11-05-2002 | 07:41 PM
Default Os 46 Fx
The aerodynamics of propellers is a somewhat grey area to me, but i recon you should use a file or sanding block instead!
