OS 55ax
Well broken in and flown OS .55AX on bench.
Weather, low 80's, very humid, just after 3 days of rain in NW Florida.
Fuel: Omega 10% Castor blend
Tach: Thunder Tiger mini-digital
Props: All APC
Muffler: Stock with baffle and Jett-Stream ordered for the 55AX
10-6 Stock: 15,700 Jett: 16,500 Gain: 800
11-5 Stock: 14,000 Jett: 15,000 Gain: 1,000
11-6 Stock: 12,800 Jett: 14,500 Gain: 1,700
11-7 Stock: 12,200 Jett: 13,700 Gain: 1,500
Comments:
1. Looks like the 55 isn't going to be a really high rpm engine
2. The Jett-Stream is supposed to be designed for the 11-6 and it gained a bunch on that prop.
3. I was surprised that the 11-7 gained that much.
4. Looks like high 12's to low 13's is the sweet spot on the ground.
5. I should probably go back and do some 12" props. A 12-5 might be right in the sweet spot
Props: All APC
Comments:
I took some more readings with the Jett-Stream only and some 12" props.
Temperature: low 80s
Humidity: medium
Fuel: Omega 10% nitro, castor blend
Props: All APC
Muffler: Jett-Stream
12-4: 15,000
12.25-3.75: 14,500
12-5: 14,600
The 12-4 looks a little small.
The Jett-Stream looks like a good thing for the 3D people who like the 12.25-3.75 wide blade.
I didn't have an APC 12-6, but I'll bet it would be good, too. Probably be the best sport prop.
Humidity: medium
Props: All APC
12-4: 15,000
12.25-3.75: 14,500
12-5: 14,600
Hello again Ed !
Real good numbers
Your engine likes the 10%. I'll have to try that using my Ultrathust muffler.
The 11-7 is the sport prop of choice for 40 sized planes IMHO. You may be right with the 12-6 for 50-60 sized planes. I've had the best results wth the Master Airscrew's S-2 series 11-7 rather than the APC... that surprised me.
Betcha the 3D guys would like the 13x4w prop too, this thing like big lumber
Real good numbers
#32
NV
APC 12*7 11900
Zinger 11*8 13800
15 perent nitro
Used this engine in a modeltech p-51. Besides the plane weighing in at almost 7 pounds for a 46 plane it flys it well.
Zinger 11*8 13800
15 perent nitro
#33
New OS 55 AX, 45 minutes run time. 10.5x7 Zinger break in prop, 10% Cool Power fuel, 3,500' altitude, 70 degrees F. Stock muffler w/baffle in place. 13,500 RPM.
Switched to 11-7 APC sport prop. 13,000 RPM.
Typical top quality OS product. Fires right up, excellent idle right off the bat. I bet there is a lot more power to be found here with tuned muffler/pipe, nitro, etc.
This engine replaced an OS 46 AX in a Graupner Skylark (50 size sport pattern plane) that weighs about 5.5 lbs empty. Significant performance gain! I will post more numbers as time permits.
Happy flying,
Robert
Happy flying,
Robert
#35
My Feedback: (14)
That's the perfect prop for a Fox Eagle IV .74.
I've seen a lot of changes over the years, but seeing forty sized crankcase engines (regardless of displacement) swinging such large props still amazes me.
No, I'm not being critical of anyone choosing to use these props since it is obvious that the engines are handling it well.
In the meantime, I'll still being using 11x6 to 10x7 props on such engines. Old habits are hard to break - plus I love the sound of a screaming two-stroke. Up until they escort me off the field. <G>
Ed Cregger
Ed Cregger
#36
It does handle the 12x7 just fine, but I'm thinking the 12x6 is a better fit for this engine. This engine is in a pattern plane and I'm going for more of a "4 stroke" power band, which is why I'm running the bigger props.
P.S. - O.S. recommends a 13x6 on the high end, this has got to bog the engine down. My tower .75 only turns like 12,000 on a 13x6 (when I can get it to run).
#38
Hey - WM T-34 O.S 55 AX Macks Tuned exhaust 4.750 header length
10/8 apc 15,500 to 15,700 on the ground .
10/9 apc 15,200 to 15,000 on the ground
but both fully unloaded in the air , the engine sounds the same peaking
next week we will try a 10/10 but I belive that 10/9 is max
#42
hey there Brew--- I have pushed 55's to there limit and there is no way you are going to get a decent R.P.M with a 10 X10 , if your lucky 10,500 to 11,500 . A 10 x9 is the max for that engine and I have tried alot of differnt exhaust systems and fuel combos to back up my position .
#44
My Feedback: (14)
ORIGINAL: t-34
And what happens when you pull the nose up in an extended straight up ascent? That's what I'm talking about...<G>
Ed Cregger
#45
ORIGINAL: Brew07
Hi
I am going to run the 55ax in the new Sundowner 50 was going to try a 10x10 prop. Think this would make a good combo for speed?
thanks
Hi
thanks
Try a Master Airscrew 11X7 ( S-2 style ! ) to start with, fits right in between a APC 11-6 and APC 11-7 for prop load.
Good luck
Hey Joe, My P-51 is ready. Test flight on Wendsday PM if the weather holds. Has a mistery prop on it[>:]
#46
ORIGINAL: t-34
#47
jeffk464,
10,200 with an APC 12x7 seems low.
I get 10,400 rpms with that prop from the FSa .56 4-stroke and everyone else's figures seem to suggest the .55AX should trump the 4-stroke by a considerable margin.
#48
I have lost 2 muffler halfs on the 55ax power box. I have tried red lock tight on the nut on one but it did not work. Any other suggestions to keep the pipe together? I was thinking of using JB weld on the next one.
#49
I use RTV silicon sealant on the mating surfaces and bolt threads.
The brand i have is Permatex and is rated for high temps.
Give it at least 24 hours to cure and it works well. I've never had a a muffler come loose when using it on both 2 and 4 strokes including heli and gas motors
#50
ORIGINAL: Brew07
