differences in SLT RX?
My Feedback: (325)
A couple of questions regarding the SLT RX from Tactic:
What's the difference between the 2 TR 624? I have some that are bigger and weigh 10 grams instead of 8 grams. It is slight difference?
How can one tell which SLT will bind to the newer TX and/or the older TX and the anylink? Primarily the TR 624 , 324 , and 424.
Thanks.
Thanks.
If you have a Tactic SLT transmitter, it will link to Tactic SLT receivers. The key is "SLT". Earlier Tactic systems did not use the SLT protocol, and so will not work with SLT systems.
As far as receivers go, we are aware of only one version of the TR624 receiver.
My Feedback: (325)
All the Tactic RX that will not link (bind) are labeled "SLT".
Perhaps we can tell another way instead of reading the SLT label?
As far as the TR624 rx goes , it isn't a big deal. I've not seen any troubles with them or anything. I just wondered if there were any differences other than the obvious weight and size. I surely don't think that these two questions are related , but I might just try to bind the larger TR624 and make sure they work with anylink.
Thanks for response.
If your receivers are Tactic SLT receivers, and they will not link to a Tactic SLT transmitter, then something is wrong. Please make sure the receivers are very close to the transmitter while linking. Also, please make sure that any 2.4 GHz equipment in the house is far away or turned off. Many times, wireless computer routers cause problems indoors. If you still have difficulties, then please send all the affected quipment to the service center.
