Tactic & AnyLink Support Forum Ask any questions you may have about AnyLink and Tactic systems here and get answers direct from their team.
large scale gas power a/c
Old 08-07-2013 | 11:02 AM
Default large scale gas power a/c
Could you safely use a tactic 650 r/c system in this type of plane?
Old 08-07-2013 | 11:21 AM
Bax
Yes. However, just like you'd do with any other equipment, make a careful range check before each day's flying to be sure of your aircraft and radio installation.
Old 08-18-2013 | 04:15 AM
Has anyone just used this small a rx with high power servos and not had some sort of power system between rx and servos? I am concerned about the rx handling the current load to the servos.
Old 08-19-2013 | 05:45 AM
Bax
The receiver isn't the problem. You need to make sure that your battery pack and switch harness can handle things.
