Monster GT anyone have one?
#6877
CA
RE: Monster GT anyone have one?
Hey guys I put my evader pipe on my mgt just for fun. I was LMAO it sounded just like my evader and looked like it had just about the same performance. Well any way does any one run the lst2 pipe and header and if they do hows it perform.
#6878
WA
ORIGINAL: snowbl!nd
Opened up my tranny today and found this... Somehow it was running ok even with a snapped transmission pin! Replaced it as well as the 2-speed gears which were showing quite a bit of wear after 7 gallons She's nearly all ready for racing on sunday now [8D]
[EDIT] Took the shaft out and it was only very slightly bent, not nearly as much as the photo would suggest. Don't have a spare so it'll have to do for now
And the hub is on the shaft right, I checked twice now!!!![:@]
#6879
1 Post
^^ Yeah i've killed one of those in the past, sheared off right by the pin-hole. They look pretty sturdy so much have taken a bit of force to do it [X(]
#6880
Well today was going great till this.
Funny thing is, i have no idea what happened. i was jumping the bump at the end of my driveway, getting less than half a foot of air, and then i run it over to me and noticed the left wheel totally turned to the left. i was like [&:] But oh well, from what i see i can go to my lhs sometime soon and get 2 brand new (But stock) ones for it for like 6.50.
Does RPM make these? If not, does anybody make nice aluminum ones. OR what would anybody suggest?
And one more thing, do i have to take the whole A arm(s) off to get this off?
Thanks[8D]
Thanks[8D]
#6881
1 Post
Yep RPM make them > [link=http://www.rpmrcproducts.com/products/assoc/AssocMGT.htm#carriers]clicky![/link]
I've tried aluminium ones (hardcore) in the past, but they caused binding of the axles (crushed the bearings) so switched back to stock...
#6883
FL
That's the same place all my stock knuckles broke. Get the RPM knuckles, it'll save you a lot of money and frustration in the long run.
#6885
[&o]With the RPMs if u have the 28 version axles u will need to grind the axle pin on 1 side flat until it slides into the hole, i did that on mine and mine are runnin beautifully, about 5 gallons on them and no wear. Mind u havnt driven my truck in the last 2 months
#6886
Hey thanks for the information. When and if i go to the lhs tomorrow, i'll take a look at what they have. I'll see if i can get them to order the rpm's.
#6887
ok need some advice, ok well the MGT has been down for about 2 months, mainly because of the dam carb. The problem im having is, after runnin for a while it will slide out (yes the pin is tight) and then well it falls out i loose fuel supply and it dies. Now ive found the problem, the area t hat the pins conpress on the carb body, has sort of collapsed ever so slightly. So its now not grabbing it like it should.
Now any ideas on how to get it to grab? Ive thought of electrical tape, or something similar but its just gonna wear away and yeah slide out again.
So whats everyones ideas?
#6888
hey there above me..not tryig to distrct people from helping you..just making my post too. ..
so in the first pic can anyone confirm that this is a seperate piece. I took aprt the tranny that caming with my eBay "rolling chasis" purchase and it appears that this "shim" is missing...
then in the nect pic..what the heck is that part ? another shim of the same kind ?
#6890
FL
ORIGINAL: scottywilkes
#6891
the carb is coming out of the block, allready tried some silicone and RTV, it just breaks free and slides out, starting to really piss me off. Really wanna drive it but with it like that i can only run on flat ground, and even then it still slides out, i do a couple large jumps and its gone.
Dont want to spend money on the motor as its at 10gal mark and yeah not really any point to replace the carb. The motor still has great pinch, but yeah id rather save the money for a LRP28 or STS28
#6893
#6894
MI
scottywilkes you have had your MGT longer than I have had mine, but a couple things. Is ther any chance that the servo adjustment is out and it keeps pulling against the carb even after it is all the way open? You could clean it good with brake cleaner and J B Weld the carb on. If you have a strong servo (like the stock steering servo) pulling against it though I don't know if even JBWeld would work for long. It sure sounds like something is binding though.
Good luck
Good luck
#6895
stock break servo is still on the throttle duties. Ive got the trim set so it gets to WOT and then stops, so i dont have an excess force pulling on the carb, i take my carb apart now and then, and would prefer something that is well temporary, that i can replace etc.
Got the motor infont of me as we speak, thought id have another look at it, i will proly grind a little of each of the tabs that compress onto the carb body, so it narrows the area that it compresses on. Dont know, just did a mock setup now, and it seems to be holding good, but im sure after a few large hits it will work its way loose again
#6897
Hey guys,
I got the mgt fixed today. went to the lhs and got the last set of RPM knuckles for the MGT. had to grind down the axel pin a bit, but no biggie [8D] Didnt get a chance to take it out today though as it was like 35+ really humid [:@] Anyway, i was wondering if any body had any advice on setting the suspension to make it wheelie; currently i have it on a "Raked" profile (Back end higher than front end) with the suspension preloaders. Im pretty sure i have it almost dead on with tuning, full gas it takes off, doesnt sputter and accelerates to top speed with lots of blue smoke, but im not positive. Anyway if anyone had some advice that would be awesome!!
Thanks![8D]
Thanks![8D]
#6898
And one more thing. what do you guys think about jumping into corn to practice proper takeoff and stuff? i got two of those little skateboard kickers and figured the corne would be softer than concrete
#6899
any thing soft for learning is goofd lol, i used my front lawn HAHA, looked like someone had dug holes all over it when i first got the truck.
Corn should be good, is it tall? If its the tall corn we have here then when u hit it it might make the truck flip and break, if its grass level, or tall grass level then it will be fine, i found out the hard way when i hit a very small over hanging branch of a tree, awesome stack, yet it did crack the rear shock tower
For wheelies get your self a FOC and a LST pipe, mine never really wheelied when stock, but once i got the pipe and FOC it was great, wheelies on demand
