Monster GT anyone have one?
#6977
CA
RE: Monster GT anyone have one?
Alright im on ebay and im going with an lst2 pipe and header and if i can find one cheap enough im going to get the mach 427.
#6978
CA
hey guys Whats a good combo of diff fluid for racing. For front and back. I decided to shim my diffs and i was going to change my diff fluid when i did that.
#6979
CT
You can also run the xtm pipe.I have them on both my trucks and like them a lot.I was running the losi sport pipe and think the xtm does a better job.I don't race but use 10k in front and back difs and find a vast improvement over stock.I know some are running 30k up front and 10k in the rear and find it good.
#6981
NY
I race with 30K front and 10K rear. Sweeeet setup.....
ORIGINAL: Snaut Rocket
#6982
Hey guys i have a question.
I use omega sidewinder 20% nitro. while reading the back it said to NOT use after run oil because it already has something in it. What should i do?
Thanks in advance[8D]
#6983
CA
you should be alright if you put it in after all the gas is ran out.
and guys I just put my tower oder in. I got some shims, diff oil , 8 ft shock caps and 8 copper springs coming.
and im on ebay looking for a lst2 pipe and header.
#6984
http://www.greathobbies.com/producti...od_id=ASC21141 will these work for shimming my differentials on my mgt?
Also, what would be a good fluid (front / rear) for mostly bashing?
thanks![8D]
thanks![8D]
#6985
CA
just go by this link.
http://monstergt.com/articles/transm..._diff_shim.php
#6986
I already looked at that, i was just wondering if these would fit, as you can see theres no size. i was just going by the "RC18T"
so thought it might be similar. i dont really want to order from the us (PITA)!!
thanks though[8D]
thanks though[8D]
#6988
what would be the best bang for the buck as far as engines go?im not happy with my wasp 28.would it be wise to pop a .30 in my mgt? or should i stay with a 28? i was considering getting the z28,is that engine any good?
#6989
hey snaut, if your bashing the 8 copper springs will be ok, your truck will be very bouncy and want to flip when turning alot, if u want it to not bottom out then thicker oil is the choice, if your racing, forget about the copper springs, 8 of them and u will be flipping and tumbling and bouncing all over the track, best setup for racing is all red springs, i found for light bashing that 1 blue and 1 copper on each corner worked well, even when WOTing of my ramp
#6990
CA
Yo thanks scotty i'll do that then. I was just going to expierment with it. Does anybody know if the lst2 mamifold will fit ok on the mgt cause of the roto start.
#6991
OR
#6993
OR
ORIGINAL: Evader ---> MGT
teck boiled his and bent the manifold to clear the PS.
#6995
WA
have you tired to unscrew them off? have you even bother looking into the manual to see how there assembled? you keep on asking all of these questions and you could easly figure it out on your own!
#6998
OR
ORIGINAL: farknben
hi ducked, kinda suprised u havent gotten booted from here yet. sorry others, im on a cell and it sucks! hi scotty!
#6999
how do you take the tops off the shocks. do they unscrew off.
yes they do bud...I had to do it recently. Use a crescent wrench and snug it up on the six sided nut like portion of the piston and then firmly but gently twist the top.
#7000
ORIGINAL: ferrariowner123
and thats a problem to YOU, why ?. isnt that what this forum is for to ask questions. How do you know he hasnt already !...Whats with you grouchy guys anyway. Do you wake up this way and go thru you entire day like this. Give it a rest. ![sm=pirate.gif]
