Go Back  RCU Forums > TEAM RCU > Team RCU - Don Szczur
Reload this Page >
F3A Model Apollo
Team RCU - Don Szczur Ask your questions directly to Don Szczur, proffesional pattern pilot
F3A Model Apollo
Old 06-26-2023, 02:29 PM
Don Szczur
Don Szczur's Avatar
Default F3A Model Apollo
Designed by Joseph Szczur. I was able to attain one recently with my 2003 color scheme retro-style. Thanks Joseph!
Will see if I can post some pictures of the assembly and flying.
Cheers,
Don
Old 06-26-2023, 02:30 PM
Don Szczur
Don Szczur's Avatar
Some initial pictures
Old 07-09-2023, 05:48 PM
Don Szczur
Don Szczur's Avatar
Some construction photos.
I made the rudder removable using a single wire through standard hinges. Assembly, servo setup. Very light and professionally built model at the Xtreme Composites. Very nice!
Old 07-09-2023, 05:49 PM
Don Szczur
Don Szczur's Avatar
Spektrum 5070 servos for ailerons and rudder. These are very small and powerful servos for pattern flying.
Old 07-09-2023, 05:52 PM
Don Szczur
Don Szczur's Avatar
Additional pictures.
Old 07-09-2023, 05:53 PM
Don Szczur
Don Szczur's Avatar
Tailwheel assembly is very straghtforward.
Old 07-09-2023, 05:57 PM
Don Szczur
Don Szczur's Avatar
Flies great!
Old 07-09-2023, 06:05 PM
Don Szczur
Don Szczur's Avatar
I did shift the battery back about 3 inches and the plane is very happy with the CG per recommendation by CK Aero: Just at or slightly behind the wing screw attachment. To check the CG, I slide out the wings about a half inch on each side to see the balance point then use fingers to verify the CG from underneath.
Radio transmitter is the new Spektrum NX-20. Batteries are Thunder Power 6000 10S. Rx battery 1300 Spektrum.
After just a few test flights, I can say the plane is the best rolling plane I have ever flown. I did some knife edge loops and vertical 8's and its very consistent at high-speed high throttle and low speed knife edge. Very good aerodynamics which are obviously optimized for these complicated unknown maneuvers. Well thought out design.
Old 08-01-2023, 05:50 PM
Don Szczur
Don Szczur's Avatar
Great flying airplane. The three things that stand out include: (1) Locked in lines and radius segments, resulting in reduced pilot workload, (2) Excellent and predictable snaps- places like the 45 degree knife edge up line with snap, opposite snap and the reverse ave
lance with the snap at the bottom of the outside loop. (3) Excellent balance in the yaw (no weather vane effect) which is part of why it has such a locked in feel. There are some very subtle design features that also really became apparent the more I flew the plane. My finish at the NATS is a direct result of the excellent flight characteristics of this Apollo aircraft.
Old 08-01-2023, 05:51 PM
Don Szczur
Don Szczur's Avatar
Lots of complements at the NATS on the finish of the aircraft.
Old 08-01-2023, 05:54 PM
Don Szczur
Don Szczur's Avatar
Some motor and speed control settings c.o. Brenner's Contra thread. I flew the Mezon 85 Evo at the NATS with Contra V4
Poles = 14 for Pyro 600-09, 10 for Pyro 650-83
Timing = 24 degrees
PWM frequency = 16khz
Acceleration = Normal, 1 second
Low Throttle Pulse Width = Auto
High Throttle Pulse Width = 2.05ms
Brake = 30% with 1 second on time
Henning,
I have completed some flights with the V4 and the D3 ESC and the 18SZ transmitter. Falcon 23x20F and 23x22R, Pyro 600-970, Allure @ 4550g with TP5000s.
The endpoints for the throttle are set at 120% on the low (1193us) and 109% on the high (1980us). 114% on the high will show 2000us, but I am using 109% to allow some overhead for the governor to keep the maximum power the same at the end of the flight when the battery voltage has dropped. I tried to make all curves close to the same power with the throttle stick in the middle position, so it is easier to change between curves without causing a sudden change to the motor power.
Takeoff Landing throttle curve
I use a 3 position switch to makes small changes to idle speed on the throttle AFR curve.
990us (zero RPM).
1193us (slow idle). Futaba “rate” on the mixing curve is -65, and this is for sitting on ground with props spinning.
1243us (fast idle). For landing pattern – sometimes I change to slow idle (1193us) just before landing.
1980us (full power). Futaba rate is +100.
Advancing throttle curve has delay of 24 (about 4 seconds).
Reducing throttle curve has delay of 21 (about 3.5 seconds).
Normal throttle curve.
1652us (low power), rate is +29.
1980us (full power), rate is +100.
Advancing throttle curve has delay of 22.
Reducing throttle curve has delay of 20.
Because the throttle is moving over a much smaller range, the time it is taking to go from lowest to highest throttle in this curve is about 0.8 seconds, and about 1 second.
Spin throttle curve
1213us (medium idle). Futaba rate is -61.
Advancing throttle curve has delay of 24.
Reducing throttle curve has delay of 21.
Stall Turn throttle curve
1243us (fast idle). Futaba rate is -55.
Advancing throttle curve has delay of 21.
With this setup, the throttle response is quite crisp at all times in the air - the D3 is extremely powerful. Under some flight conditions, it is possible to have a prop "buffeting" sound if the throttle is reduced too quickly. I believe this sound comes from the relative prop disc RPMs getting very slow. Once this happens, blipping the throttle will bring the RPM back up, and the buffeting sound goes away. The buffeting can also be avoided by using a higher RPM for low power (also reduces maximum braking), or increasing the delay time when reducing the throttle (makes the throttle feel sluggish to me). It definitely took quite a few flights to get the overall throttle feel I wanted in the air, and it is definitely different than flying a traditional ESC. Some pictures are attached to show the shape of the throttle curves.
Hi Dave and Peter,
The weather over the x-mas holiday has been good enough to test the D3 ESC. We only have 4 hours of flyable daylight at this time of the year but over some days I have logged 29 flights.
In general I like the D3 once in the air. The start up and landing sequence with changing throttle curves by a 3 pt switch will take some more time to get used to. I hope to get some more flights in the upcoming weekend.
V4 600 14 Pole Mejzlik 22x20F and 22x22R used for windy conditions.
Futaba 18MZ
ATV
Full 108%
Low 124%
Normal flight
Full 1.910 ms
Low 1.592 ms
Speed In 16 Out 16
I have reduced the full power on both the ATV and the throttle curve.
Idle 1.054 ms
Speed In 0 Out 10
Takeoff/Landing 1.210 ms
Speed In 16 Out 16
Throttle hold/off 0.953 ms
Spin 1.367 ms
Stall Turn 1.637 ms
Speed In 16 Out 16
Br
Henning
Old 08-01-2023, 05:59 PM
Don Szczur
Don Szczur's Avatar
Pictures from the NATS.
Apollo with CK Aero co-owner Bryan Hebert
3rd Place F3A, US NATS
F3A Finalists 2023 NATS
1st Place Brett
2nd Place AC
3rd Place Don
4th Place Greyson
5th Place Mark
6th Place Forrest (not pictured)
Old 08-01-2023, 06:02 PM
Don Szczur
Don Szczur's Avatar
4497 grams ready to fly at NATS check in. CG as recommended just at the wing screws.
Servos 5070 Spektrum ailerons, rudder, 5060 on elevators
Spektrum NX20 transmitter
Thunder Power 6000 10S batteries
Spektrum 1300 maH rx battery.
Old 08-04-2023, 04:00 AM
YmeF3A
Beautiful model. How much mAh do you use. And what is your average speed?
