TEAM RCU - Mike McConville Ask expert Team RCU pilot Mike McConville questions in this forum.
Tensor 4D
Old 10-30-2004 | 01:28 PM
Default RE: Tensor 4D
So far I've been running the lower kv motor. Havent personally tried the higher kv one yet. I did however run the 2208 26 on my Tensor at the eToc and liked it.
Old 11-01-2004 | 02:01 PM
flyinrazrback's Avatar
My Feedback: (69)
Mike, can you tell me the difference between the 1080 and 1360 e-flite outrunner motors? are they the same size as each other? Also, are the tensors going to be out this month or December? Thanks!
Old 11-01-2004 | 02:12 PM
Yes they are the same size. Just diferent windings, thus different Kv. The Tensors will be close as far as making this month or Dec.
Old 11-01-2004 | 02:17 PM
GRH
flyinrazrback,
I'm not trying to answer for Mike here but there's a little explanation of the difference between the two Kv values at the following link...see post #8. I've been flying both the new E-Flite outrunner motors and they are the same case size with different windings. (22mm diameter and 8 mm bell length)
George Hicks
http://www.rcuniverse.com/forum/ulti...2281553/tm.htm
Old 11-01-2004 | 04:02 PM
My Feedback: (69)
George, thanks for the info, which motor do you recommend for the tensor when it comes available?
Old 11-01-2004 | 04:33 PM
  #31
GRH
Either will work...I like the 1080Kv with the 10x4.7 prop...I get longer flight times with it than the 1360Kv motor but not quite as much thrust at full throttle. I like to use a 12V 730mah Li-poly for flying outdoors and the 7.4V 730 for indoors.
George
Old 11-01-2004 | 04:49 PM
  #32
My Feedback: (69)
Thanks, what brand of li-polys are you using? I was using a kokam 2c 340 and an axi 2208/34 on my shockflyer, but was disapointed that I was only getting about 5 minutes per flight.
Old 11-02-2004 | 08:22 AM
  #33
GRH
I like the Duralite Thunder Plus pack with the charge protection. The new high-discharge Thunder Power cells that they use are great. I like the new 730mah for the Tensor. For longer flight times I like to use the 1320 2-cell but the 3-cell 1320 is too heavy for the Tensor in my opinion.
George
Old 11-02-2004 | 12:17 PM
  #34
flyinrazrback you where getting 5 min with one 2 cell 340mah pack or two ?
Old 11-02-2004 | 06:37 PM
  #35
My Feedback: (69)
5 minutes with a 2 cell 340 kokam
Old 11-10-2004 | 09:49 AM
  #36
My Feedback: (69)
Any updates on ETA of the tensor?
