TEAM RCU - Mike McConville Ask expert Team RCU pilot Mike McConville questions in this forum.
Tensor 4D
Old 08-04-2004 | 07:13 PM
simon 3d's Avatar
Default Tensor 4D
[:-]Hello Mike,
Good to see you on RCU, i wonderd if there is any news on the TENSOR???
Cheers
Simon.
Old 08-05-2004 | 03:58 PM
Default RE: Tensor 4D
Hi Simon,
We are wrapped up except for producing the instriction manual. It will likely be released to the market in November. Worth the wait.It is a very cool airplane.
Mike
Old 08-05-2004 | 06:46 PM
simon 3d's Avatar
Hi Mike,
Thanks for that, canot wait to get my mits on one, is it possible to pre-order ??
Cheers
Simon.
Old 08-05-2004 | 06:51 PM
Not yet, but it will be possible soon. Then you can preorder through your LHS, or from Horizonhobby.com, however the LHS will probably get one a little sooner.
Old 08-12-2004 | 04:29 PM
Mike,
Any chances of finding out what power system you flew in yours at the ETOC? I'd like to get those items bought now.
Wiz
Old 08-13-2004 | 09:15 AM
I was running the AXI 2208 26 at the eTOC. A good outrunner in that class is the best set-up.
Old 08-13-2004 | 12:17 PM
Well, I'm in luck then. I happen to be running that exact motor on my Shockflyer with a 2S lipo pack.
Thanks Mike!
Old 10-12-2004 | 05:19 PM
Mike, I was looking at the pics. of your T,4D at the E-TOC. Q, Can the battery placement apply to the T,4D as with the E-LITE Ult.Bipe.
Old 10-12-2004 | 08:52 PM
Hey John!
Howz the Houston boys doing?
Old 10-12-2004 | 10:15 PM
Hey Wayne!
Were doing OK. Ron Bar & Steve are ''HOOKED'' on Electrics now. Ron has dropped about $1000 in 2 trips to New Creations . So I would saw he is ''WAY HOOKED'' cool.
How you doing? What do you think of the Tensor 4D? Saw one fly, Well A knock off of one looked pretty cool. Hey if you know anything about this Bipe e-maile me?
Old 10-12-2004 | 10:22 PM
John,
The Tensor is AWESOME! You kinda have to retrain your thumbs a little but its very easy to get used to. It does some very cool things.
How about Rolling Harriers with no rudder input? Want to change roll direction in a rolling harrier? Just move the aileron the other way. Keep in mind, you still havent touched the rudder yet...
I have 2 on order!
Old 10-13-2004 | 09:00 AM
The battery location in the Tensor is very different than the Ultimate. It needs to be high in the Ultimate to get the correct vertical CG. The Tensor layout is very different, must more symmetrical, thus the battery does not go as high is it does in the Ultimate.
Old 10-13-2004 | 03:47 PM
Thanks,Mike
When will they hit the HS? I guess the AXI-2208/34 & 10-4.7 apc will do the trick?
Old 10-13-2004 | 09:12 PM
Mark Dennis's Avatar
mike, i have an eflite 370 and also a himax 4100-2500 do you think either one will work this one looks like a lot of fun.
thanks,
mark
Old 10-18-2004 | 10:17 AM
I'd use an outrunner. The 370 (B20) sized inrunners are a little heavy for the Tensor. Therer are new E-Flite 370 outrunners coming around the same time as the Tensor.
Old 10-19-2004 | 12:53 PM
Those outrunners look almost identicle to the AXI outrunners. Except they chose a better color and the edgest look smoother... Cant wait to see a shootout between these and the 2208 series...
Old 10-26-2004 | 03:42 PM
The E-Flite outrunners are also considerably less costly, and they come with the mount and prop adapter.
Old 10-26-2004 | 03:48 PM
flyinrazrback's Avatar
My Feedback: (69)
Mike, when are the tensors supposed to be available? also, which micro jr servo would you recommend, what speed control, and what lipo battery would be the ticket?
Old 10-26-2004 | 05:03 PM
We hope to have the Tensors out in late November. I use the JR 281 servo. Castle Creations Phoenix 10 speed control. Thunder Power 730 2-cell is best for flight performance indoors. outdoors the 1320 2-cell is better.
Old 10-26-2004 | 05:31 PM
My Feedback: (69)
Thanks Mike! if they fly like the videos I have seen at the E TOC, that plane should rock.
Old 10-26-2004 | 07:01 PM
Trust me, it rocks!
Old 10-27-2004 | 06:09 PM
My Feedback: (69)
Mike, is the outrunner equivilent to the axi 34 that I have? thats what I got on the shock flyer now, but like the prices better on the outrunners.
Old 10-27-2004 | 06:11 PM
My Feedback: (69)
Old 10-28-2004 | 10:24 AM
We have 2 new Outrunners. One is 1080kv that is equivelant to the AXI 34 and also a 1360kv that is more like the Axi 26.
Old 10-29-2004 | 04:53 PM
nate1001's Avatar
are you running the higher or lower kv motor from e flite? I want to order now so when they come out I'll be closer to the top of the list
