Main Rotor Blade...?
My Feedback: (167)
CA
Hi...
I have R50 and R30.
I just wondering that Can I use 550mm blade for Raptor 50?
Or...620mm blade for Raptor 30?
I'm just scary to fly with different blade.
I have R50 and R30.
RE: Main Rotor Blade...?
You can use 550's on the 50 if you want but they don't work as good as the 600's, you can't however use the 600's on the 30 machine.
Colin
Colin
I wouldn't try the 550mm on the Raptor 50 if I were you....You might or will overspeed the blades and that's not going to be pretty, unless you got a governor on your heli......Stick with the 600mm for your Raptor 50, it performs better.....and your heli will be much happier......And like raptor_dude said "you can't however use the 600's on the 30 machine" because the tail boom is to short for those blades and they will hit the tails blades.....
