reflex sim help
reflex sim help
hi there i just got a reflex sim to practice nose in hover but cant get it to be as stable as flying the real thing does anyone no what setting should be done on my radio JR 9x PCM version 2 or the settigs i need to do on the sim or no where i can get it from
thanks any help would be great
ON, CANADA
RE: reflex sim help
Start off by selecting a new model for your trainmitter. Then, reset any pre programed information, and start from scratch. Make sure the model is set to heli mode, and not airplane.
Then set up your radio exactly how it says to do in the sim. I'm not at home right now, so I can't check what you click on to set up the trainmitter, but you will figure it out. Its the one that says to center all gimbles and trims. Then just do exactly as it says, follow the dirrections, and everything should work out. Perhaps you should try flying a different model.
For a more detailed answer, click here http://www.raptortechnique.com/reflex-xtr/index.html
Hope this helped.
Hope this helped.
RE: reflex sim help
I have the reflex sim and a Caliber 30.
I notice the reflex Caliber 30 is harder to hover and more sensitive than the real chopper.
You could reduce the sensitivities on the sim by changing the ailerons and elevator from say 0 to -20% (or more).
