 parallel pushrod connector? >
Old 04-04-2011 | 06:48 PM
Default parallel pushrod connector?
Is there a connector of some sort that will allow 2 pushrods to run parallel close to each other?Tower had one at one time ,but dont seem to carry it anymore,Ive tried all the other suppliers but to no avail...
Thanks-TAZZZZ
Old 04-04-2011 | 06:57 PM
MinnFlyer's Avatar
Default RE: parallel pushrod connector?
Do you mean like item #S558 on this page?
http://www.sullivanproducts.com/ContSysAccMainFrame.htm
Old 04-04-2011 | 07:26 PM
Yikes,,,,,why cant I find those under Towers listing of sullivan products? I found it,,Thanks But the one I was talking about is about 3/4" long and has three holes that pushrods go thru each hole has its own set screw. Its kinda barreled shaped..
Old 04-05-2011 | 11:51 AM
I know what you speak of because I kept one from my crashed T28 (Blackhorse 60 size). Perhap you can find a parts listing for that model and order the part?
It would be fairly easy to construct if you have a drill press and tap for the wire and set-screw size you want.
Regards,
Clay
Old 04-05-2011 | 11:58 AM
I think you mean these at Hobby People:
http://www.hobbypeople.net/index.php...2pcs-pack.html
Bruce
Old 04-05-2011 | 04:28 PM
You could join the two pushrods with a wheel collar.
