Correx/coreflute adhesive. >
Old 04-15-2002 | 09:24 AM
Default Correx/coreflute adhesive.
Can anyone advise what adhesive/glue is suitable for sticking the correx/coreflute board to itself and to balsa.
In the UK they have a Bostik product (I think) called EVO-STIK impact adhesive, which is unavailable under that name in Australia.
I have tried liquid nail type construction adhesive and though it seems fine, it takes about 5 days to set.
Nigel
Old 04-15-2002 | 09:33 AM
bkf
Just about any SOLVENT based contact cement works.
Old 04-15-2002 | 09:37 AM
Thanks BKF.
Nigel
Old 04-15-2002 | 01:14 PM
My Feedback: (8)
Go here:
http://www.spadtothebone.com
Everything you ever wanted to know about correx/coroplast etc and a bunch of neat airplanes to build from the stuff as well!
You can glue this with thick CA type glue after removing the mold release agents from the plastic. The website will explain how to do that.
Old 04-15-2002 | 03:11 PM
Jetmex:
Tried several times to get the site to come up.
When I did a little help with our club Spad projects, we sanded
the area to be glued then cleaned with alcohol. We used the
med. Ca for the aileron lap joint and epoxy for the yard-stick
airfoil spacer.
Old 04-15-2002 | 04:04 PM
I clean the coro by "flashing with a propane torch, then I clean it off with alchohol, using CA only use a small drop every 1/4" or so, if you use to much it makes a mess and does not set up worth a darn. Practice the flashing on a piece of scrap, takes a little getting use to, you just want to burn off the release agents (oils?) off the plastic, if it warps slightly wait for it to cool down and it should go back to its origional shape.
John
Old 04-15-2002 | 04:26 PM
We do virtually the same thing as John B, however we use a heptane base cleaner after flashing, then we run a woodpecker to perferate the coroplast...this seems to give the extra CA some place to go. We also use Thin CA, just small dots every 1/4" or so.
We purchase the Cleaner as part of a plasitc glueing kit from Lowes or Home Depot. You will see the little jar of cleaner with the glue...it's easy to find.
We have built many wings and never had one come apart. We also tried to take one apart...you can't pull it apart.
Good Luck.
Eric
Old 04-16-2002 | 10:33 AM
Thanks for all your replies guys.
This really is a wonderful site.
Thanks particularly to jetmex for the link to spadtothebone, it really has everything you need to know.
Nigel
Old 04-16-2002 | 12:56 PM
My Feedback: (8)
You're welcome, Nigel! Hope your projects come out ok....
