bubbles in covering >
bubbles in covering
bubbles in covering
Old 08-21-2003 | 11:17 PM
My Feedback: (109)
Default bubbles in covering
I have never bought a ARF or used monokote-but got one for birthday-How do I get those bubbles out of the -balsa covered foam wing on Dragon Lady 60-also bubbles on deck -the more heat you apply the bigger the bubbles get-thanks
Old 08-22-2003 | 12:21 AM
bokuda's Avatar
My Feedback: (7)
Use a needle and poke a very small hole in the center of the bubble. Use a sealing iron and iron from the edges of the bubble toward the hole, forcing the air out. Done properly, the hole will not show or barely show..
You'll need to experiment for the right temperature. Too much heat causes the adhesive on the covering to give off gas which creates bubbles. You want to find the temperature that will adhere the covering to the balsa, but not create gas bubbles.
Old 08-22-2003 | 01:15 AM
Be VERY cautious of the heat on a foam wing! It won't take much to ruin the foam underneath the covering.
Dennis-
