Can CA hinges be removed with deboner?
My Feedback: (7)
NJ
I used CA hinges on my Balsa USA stick for combat. The stab has a nasty flex in it when the elevator is deflected. I think something somewhere is not straight. I would like to remove the elevator to try again. The hinges were put on a few days ago with thin CA. Will soaking debonder into the hinges work for removal?
Thanks!!!
Thanks!!!
Moderator
My Feedback: (58)
Nick, unfortunately, debonder will not work. Cut off the hinges and cut new slots next to the old ones. You could also replace the ca hinges with robart hinge points. There was a thread I posted some time back on how to drill through the old ca hinges.
Moderator
My Feedback: (58)
Here's the link on replacing ca hinges with robarts http://www.rcuniverse.com/forum/m_13...tm.htm#1338490
Deboner.........try some hydrofluoric acid [X(]
CA
ORIGINAL: rajul
Jackjet
CA
ORIGINAL: rajul
Jackjet, I said that in jest.........HF acid is a real de"boner" as it attacks bone quickly. Pls don't ever use it as a de"bonder", it has no place in R/C
Hi Rajul,
no problem,
just wanted to warn them - I used to work in a place that made silicon wafers for IC's and nitric,sulfuric,hydrochoric, and hydrofluric acids were used / I did NOT like even going in the room where that stuff was kept........one of the women got some HF on her right hand - it really messed her hand up.......
Jackjet
