 super cheap plane stand >
Old 08-03-2004 | 05:32 PM
Gringo Flyer's Avatar
My Feedback: (18)
Default super cheap plane stand
Are you looking for a cheap stand to put your planes on to while working. Styrofoam ice chests make great super cheap airplane stands. Use the base and then just cut out the shape of the fuselage. They don't damage the plane and are great for working with while the plane is upside down. I like them because if I need to push down on the plane in order to install a servo, etc. the styrofoam absorbs a lot of the weight. Maybe this is an old shop trick but for me as a new builder this has been a huge help.
Old 08-05-2004 | 03:34 PM
Default RE: super cheap plane stand
That's a good idea. I just broke one on purpose and now I wished I hadn't. [>:]
Old 08-05-2004 | 03:51 PM
smchale's Avatar
My Feedback: (67)
This is a good tip! In addition to this you can cut one pair of sides to suit the shape of the fuse right way up, then perpendicular to that on the other 2 sides you can cut it to match your fuse while upside down.
Old 08-05-2004 | 04:39 PM
My Feedback: (18)
Thats a good idea smchale. But I just cut it out to fit the biggest plane that I have and the others just rest partially on the wings.
Old 08-06-2004 | 02:10 PM
apalsson's Avatar
ORIGINAL: Gringo Volador
This is what I do. I also use the same box when I transport my smaller planes to the flying field, as the box also makes for an excellent storage for the parts and tools that are specific to that plane.
Good tip Gringo Volador
Old 08-14-2004 | 05:28 AM
LuckyArmpit's Avatar
One precaution....make sure you drink the beer from the ice chest first!!!!!!
Dave...
Old 08-22-2004 | 06:18 AM
aimmaintenance's Avatar
ORIGINAL: LuckyArmpit
Dave...
No No don't drink it first,, that's the beauty or the ice chest idea. It allows you to work on your plane and never be far from your beer.
You install a clevis/ reach in and grab
install a prop/ reach in and grab
install a servo/ go to the bathroom, come back, reach in and grab.
Old 08-22-2004 | 06:05 PM
My Feedback: (18)
I found another advantage to the foam ice chest. If you are installing a servo, canopy, anything with screws. You can stick the screws into the foam while you are putting in the other ones. That way you dont have to worry about them rolling off the table and disapearing into the carpet!
