 Decal removal >
Decal removal
Decal removal
Old 09-19-2004 | 07:18 PM
Default Decal removal
I have been flying a Sig LT-40 Arf that when I first put it together I applied the furnish decals that have the sticky backing on them. I have found that these decals are not the best color scheme to be flying with so now I want to put some brighter colors on. Does anybody have a good method to remove these decals without harming the ultracote underneath? Any advice would be appriecated!!
Steve
Old 09-19-2004 | 08:05 PM
Richard L.'s Avatar
My Feedback: (24)
Default RE: Decal removal
Try heating the decals up with a heat gun, then slowly peel them off.
Old 09-20-2004 | 11:04 AM
hookedonrc's Avatar
It takes a while, but I took off the decals on my Funtana (40 size) by pealing back a little of the most loose edge. Then I took a paint brush and dipped it in paint thinner. By putting a little pull pressure on the decal and running the brush back and forth across where the decal attaches to the plane, I was able to remove the decals without any damage to the covering on the plane. I would recommend checking on a small spot before going full blast though.
