How do they do that? >
Old 12-05-2002 | 12:55 AM
green river rc's Avatar
Default How do they do that?
How do you guys mark cross section lines, for example, panel lines or invasions stripes on a tapered fuse on a scale war bird? You can't just lay a flexible ruler down and draw. The line will come out curved. I experimented with a homemade height gage once that I made out of some wooden yard sticks, but had limited success. That's why I'm throwing this one out to all you building experts out there. Thanks for lookin'! David
Old 12-05-2002 | 03:26 AM
Go to an Art store and get a flex layuot rule , mine is about three foot long and feels like it's filled with lead.
It will bend in two directions at the same time and has MM and Inch rulers on either side bout $8.
You can also use it to duplicate/transfer shapes.
Den
Old 12-28-2002 | 09:07 PM
DeadSticker's Avatar
My Feedback: (18)
I just use masking tape to get the general lay out, then put the film down on the line I just made with masking tape. Plus when you put the tape on, if it doesn't look right, pull it off and redo it. You can round it, curve it, do anything to it and it will give you the line for your covering....
Old 12-29-2002 | 05:04 AM
TexasAirBoss's Avatar
My Feedback: (22)
1.) Stand model on nose.
2.) Support pencil or pen at the appropriate height, say on a box
3.) Rotate model as you mark the line.
4.) Apply tape along line
Old 12-29-2002 | 12:47 PM
Cactus.'s Avatar
i hear cable ties work well, or string tied around the fuz. you just mark along the edge
