 WORKING WITH STYROFOAM! >
Old 04-03-2006 | 04:50 AM
Default WORKING WITH STYROFOAM!
Are there any special techniques, gluing methods, carving, shaping, building, and fusing techniques for making things out of styrofoam?
Ex. wing , fuselage, and stabilizer making tips? Basically the whole 50 yards. Foam can be very tricky and I am making an electric foam glider so before I make it I would like to know what techniques to use and problems to avoid
Thanks, Shredder111[>:]
Old 04-03-2006 | 11:04 AM
Deadeye's Avatar
Default RE: WORKING WITH STYROFOAM!
Guys use a hotwire for cutting foam. I've done it freehand on tail feathers and a set of floats I made.
Polyurethane glue is best for wood to foam glueing
For carving, I like the disposable utility knives with the snap off blade. Brand new, and you have a 3 inch razor to cut with.
Old 04-03-2006 | 11:05 AM
MinnFlyer's Avatar
Don't use CA!
Old 04-03-2006 | 11:33 AM
Carving and shaping as well as cutting of thick styrofoam is easily accomplisted with your wifes electric carving knife.... Ask me how I know... Then ask me how long I paid for that one
Old 04-03-2006 | 03:52 PM
Here is information I previously posted
http://www.rcuniverse.com/forum/m_3951375/tm.htm
Tony Hallo
Old 04-03-2006 | 03:53 PM
And another
http://www.rcuniverse.com/forum/m_2396409/tm.htm
Tony Hallo
Old 04-03-2006 | 04:02 PM
Some photos of the cowl for a Cessna, made by caving and sanding 1/2" blue foam stacked to size, glassed, dissolved the core with gasoline after the epoxy cured.
Tony Hallo
Old 04-03-2006 | 10:21 PM
ORIGINAL: Tony Hallo
And another
Tony Hallo
Another good info link.
http://www.utahflyers.org/FCCut.php
roltech
