Cricut for cutting monokote
My wife just baught a Cricut paper cutter (www.cricut.com) so i instantly thought of cutting monokote with it. It worked perfectly when set to low pressure, slow speed, and #3 on the knife. She only has the basic cartridge that came with the machine so It's not perfect for graphics for planes, but it has a usb port on the back and the company says it will soon be upgradable to custom graphics.
it has ametal blade in an assembly that is $30.00 msrp. I don't know the longevity but since the blade vibrates as it cuts and is designed for cutting card stock, it should last quite a while.
My Feedback: (27)
WI
Where did you find the info about the USB upgradeability? My wife bought one and I had the same thoughts you did, but I wasn't able to locate any info in the USB port. The internals look as good or maybe better than my Roland Stika vinyl cutter.
My Feedback: (27)
WI
ORIGINAL: jbloom
Looks like it's about $229.00... $299 on the cricut website. Hmmm...
NC
We have a Michaeal here, I'll check it out. If it works for Monokote, that would be pretty nice. It would likely work better for the trim sheets. They're adhesive backed and look narrow enough to fit into the machine without trimming it any.
ON, CANADA
My wife just got her new Cricut machine, and I too immediately thought of using it with Monokote. Like what was said previously, it is limited really to just lettering for now,...the graphics are basic. Unless you want to cover a plane with hearts and flowers! I've included a couple pictures of the lettering I cut out for my Sig Kobra. It works great and looks awsome! It does seem to dull the blade quickly, but the results are worth the cost of a new blade.
MD
I just bought the Cricut. I love this little thing. It makes cutting letters and numbers easy. I cut out Big Orange in less time than it would have taken me to cut B by hand. How cool. I see a lot of recovering and new numbers in my future.
-Andrew
-Andrew
MI
ORIGINAL: weathervane
-Andrew
-Andrew
I think I know what you are talking about. I saw the info-mercial. Now that I know it cuts covering material do you have a phone number or website.
Bill
