G.P. Hinge Cutter Blade Change
NJ
A word of caution when changing blades on the Great Planes Hinge Cutter.
Recently I was changing the C.A. blade to the hinge blade and discovered it is very, repeat very easy for the screws holding the blades to fall inside the tool. You might think, no problem, just turn the tool over and let the screw fall out. But... that won't happen, at least it didn't for me and you will not be able to disassemble to tool because of the unique fasteners that are used.
Fortunately I could see the screw and reach in with forcepts to retrieve it. Soooo, be very carefull when changing the blades and save yourself a problem.
By the way, the cutter works great, it's the operator with the problem.
DaveB
Be very aware
DaveB
Be very aware
WA
Those special screws can be defeated but it will take an old screwdriver you're ready to throw away and you're willing to modify with a file/grinder. Once removed, they can be replaced with standard screws if desired. Mine got this treatment when I replaced the ridiculously short cord with a 10' cord that would reach anywhere on my bench. Now if they'd make it variable speed, it would really be nice.
