Where to find a bandsaw blade online >
Old 03-17-2002 | 08:14 AM
bkf
Default Where to find a bandsaw blade online
Im having a heck of a time finding a metal cutting (aluminum) bandsaw blade for my Ryobi bandsaw. Everybody sells them for wood cutting but no one I can find online sells the metal cutting ones. I need a 59 1/4" blade. Ideas? Bkf
Local stores do not have and will not order.
Old 03-17-2002 | 09:31 AM
Default saw blades
you might want to try Micro Mark at http://www.micromark.com/ they carry a lot of different things.
Old 03-17-2002 | 09:37 AM
bkf
Thanks Prof: I just looked and it looks like they only carry the 44" blades for their saw. Bkf
Old 03-17-2002 | 09:41 AM
Default blades
ok a place you can prob find the size you need is grainger.com then I usually use them when I cant find anything any where else
Old 03-17-2002 | 09:43 AM
bkf
Tried there: No got. Like I said Heck of a time.
Old 03-17-2002 | 09:44 AM
Default sorry wrong url
http://www.grainger.com/Grainger/start.jsp
Old 03-17-2002 | 09:46 AM
Default found a place
http://www.victornet.com/cgi-bin/Sof...html?E+scstore
they will even cut to order if needed
Old 03-17-2002 | 10:00 AM
bkf
Ok I went through 119 blases on Grainger. No Soap. Victor would be great if I did not have to buy $60 worth.
Old 03-17-2002 | 10:03 AM
Default worth a try
well it was worth a try. goto www.ferretsoft.com and get their webferret search engine. put in band saw blades once it is installed I got over 500 hits just gave ya a couple I am sure you can find something there. well have a good night hope that helps some.
Old 03-18-2002 | 12:05 AM
I would try, either Sears and/or Ace Hardware.
I know they sell these blades in their stores, and I would assume they would be available on-line.
Good-Luck.
Old 03-19-2002 | 02:31 PM
Default Saw Blade
bkf,
I need the same blade. Wish I had known it wasn't offered before I bought the saw.
I tried Sears. Their Catalogs shows that it is not made for metal in 59 1/4 size. Tried Harbor Freight, Home Depot, Lowes etc. No Luck.
Good hunting. If you have any luck I would appreciate the info.
Ed
Old 03-19-2002 | 03:02 PM
Default Blade Source
Have always had good luck with this source for industrial supplies: McMaster-Carr Supply Company. Their main plant/warehouse is in Elmhurst, Illinois. Have their old catalog which gives their sales desk number as (708) 833-0300, but the area code has changed to (630). They do have a website: www.mcmaster.com/. Huge catalog!!! Good luck. Regards.
Old 03-21-2002 | 09:39 PM
My Feedback: (14)
Default Check our Ace Hardware
Check out your local Ace hardware. They have a huge catalog and will order anything you need from it. I get all my band saw blades from them. It takes only a few days and the price is right. The last ones (56 1/8 inches) cost me $7.80 each.
Old 03-21-2002 | 09:49 PM
bkf
Ace Hardware did not want to know anything about ordering them. NONE of the above had them and none were willing to order them. But I found that the Vermont American 59.5" will work. I had a hard even finding them but finally did in a Lowe's store. They were sitting on the floor behind some boxes. I got luckey But if I had to do it over again I would get a band saw where the blades are in stock. EVERYONE had the wood blades but none had the one metal cutting blade. I got two. They had one more. I can pick it up and send it. I won't be able to go until tursday. Bkf
Old 03-22-2002 | 02:46 PM
bkf,
If the pick up offer was for me, I greatly appreciate it, but I'll check my local Lowe's stores again now that you've given me a brand and size that will work.
Thanks again.
Ed
Old 03-23-2002 | 03:27 AM
ScottyC's Avatar
Try http://store.yahoo.com/toolsplus/index.html
Old 03-26-2002 | 03:10 AM
bkf:
Since you already found a source, I'll just pass this along as
future ref. Kansas City has a retail parts store called Beaver Tools
where you take in the length you need and tooth count, they will
cut the length off from a bulk spool and weld it. I'm sure you
would have a similar shop up there too.
I may have missed it, but I didn't see that you mentioned what
gear reduction you have for going from wood to metal.
Old 03-26-2002 | 03:15 AM
bkf
Originally posted by rreiss
bkf:
rreiss: I don't think there is any way to change the speed of this saw. Im going to cut some aluminum so it should not be to bad. Oh well Bkf
Old 03-26-2002 | 08:45 PM
JVB
http://www.delta-tools.net/index.html
Old 03-27-2002 | 03:16 PM
bkf
Only wood blades. No metal.
Old 03-27-2002 | 04:37 PM
JVB
I just bought a band saw blade made by the M. K. Morse Company, Canton Ohio, 44711 at Menards. Menards is similar to Lowes, etc. It says on the back that the 14 tpi blades are for finishing cuts in wood and ferrous and non-ferrous metals (1/4 inch or thicker). The blade was $5.
Old 03-27-2002 | 04:45 PM
bkf
Hmmm Im looking at the back of a Ryobi blade package. It says the 14 tooth is for wood,compositions,ply wood,and plastic. I guess these blades don't have what it takes. Next time ill buy a sears.
