 Digital Servos with an ESC? >
Old 09-26-2009 | 08:25 AM
Default Digital Servos with an ESC?
Is it ok to use digital servos with a E-flite ESC? I read on the site saying that digital servos drawn too high of a current for the ESC which will cause failure. Is that true or can I just go ahead and use digital micro servos?
Old 09-26-2009 | 10:02 AM
Default RE: Digital Servos with an ESC?
I would not use the BEC in the ESC to
power the Rx and the servos. A high
mAh Rx battery would be my choice.
Bob
Old 09-27-2009 | 09:15 AM
exeter_acres's Avatar
depends on which ESC, which servos, and how many servos....
I use digi's all the time in electrics, but it was to remain within the specs of the ESC..
Old 09-27-2009 | 11:21 AM
Well i Ordered the 40A Eflite ESC, Futaba S3157 Servos (4). I was going to power the whole system with the ESC. Possible conflicts?
Old 09-27-2009 | 11:23 AM
specs for ESC are here...
http://www.e-fliterc.com/Products/De...rodID=EFLA312B
Old 09-28-2009 | 12:27 PM
opjose's Avatar
That ESC does not specify that it has a SWITCHING MODE BEC, ( something the manufacturer would tout as a big selling point! )...
As such even with the "dual regulators" I would not push it with digital servos.
You can easily and cheaply install a separate BEC to power the electronics.
