20 lb propane tank to air tank conversion?
NY
With the new requirments of grill propane tanks I now have one that can no longer be filed. Any thoughts or ideas as to convert it to an air tank.
NY
Originally posted by Shortman
this is probably a dumb question, but what are you gonna use the airtank for???
bkf/Moderator
You gave it all away. You should have left it alone and let people figure it out. I really thought it was going in the Chipmunk!!
Ed S
Ed S
NJ
sure .... i want to watch (from a distance) the first time you drop liquid co2 in that thing
its only 900psi
or you could go hpa at 3K-4.5K psi
its only 900psi
tank was designed and a no longer good after date on them compresed air has alot of moisture and tank not set up for this and will pop. by a cheap tank made for this purpose . stay safe!
NY
Originally posted by Miniair
The propqne tanks can be re-certified, the valve is changed, the tank is X-rayed for flaws and thin spots, if it passes the x-ray test then the tank is pressured up to 600PSI, it then sits for 48 hours and if the pressure doesn't drop a new certification number is stamped in the tank. The outside of the tank is sand blasted using glass beads as they don't remove metal - just paint and surface rust. The tank is then painted using epoxy based paints for durability. One of my companies does this, we do about 60 tanks a week.
I was always told it was illegal to do this because the tanks are not coated on the inside and will rust from the inside out. A aux. tank for your compressor is a great idea just go to wally world and get one made for the job. BE SAFE Just my 2 cents worth
Cubfan
Cubfan
NY
Cubfan
Cubfan
