after run oil
MT
For engines cowled I get the oil where its needed with a medium size medical syringe with a piece of fuel tubing attached then a short piece of hard plastic tube instered into the end of the fuel tubing. What hard tube does is allows me to do is connect it to the breather line of my four strokes and inject oil right into the crankcase. Note the 'plunger' of the syringe will not hold up to oil, however replacing it with an O-ring with make it work forever.
The debate of whether after run oil is necessary will always rage on. I say do what you think is best and have fun flying.
I keep a 4" length of fuel tubing. Squirt the oil in the tube (I carry mine in a squeeze bottle with a tip that fits the tubing - and use Dextron III ATF), attach the tube to the intake barb. Cover the exhaust with my finger (optional) and spin the prop a few times. It sucks the oil out of the tube.
If you have a cowl so tight you can't get forceps in to access the carb fitting - pull the glow plug.
