(SILVER-SCORPION) New Bright Rock Crawler
RE: (SILVER-SCORPION) New Bright Rock Crawler
nbcrawler ..
Your crawler has a very good flex ..
Now, you must change your motors, and perhaps install a 4th gear ?[8D]
CA
JUST GOT A NEW BODY TODAY..
ITS A 1/6 NEWBRIGHT EXCALADE..
GUNNA TRY TO CUT IT TO FIT THE 1/10 CHASSIS AND MAKE IT LOOK LIKE A SCALE CRAWLER..
ALSO GOT A 280 MOTOR.. STILL WAITING ON ANOTHER ONE..
PICS WITH BODY ON SOON..
Could someone tell me what pitch has to do with describing a pinion? Also, what size is the shaft of the motor on the stock NB rockcrawler motors? I am looking on ebay for 8 tooth pinions and they all have different pitch and shaft size. What pitch and size should I be looking to get for my new bright?
#31
I advise you to go to the hobby store, with your motor and pinion 10 tooth ..
....... and ask that you find two 8 tooth pinion ..
If you have with you ,the two 4 th gear, they will find two 8-tooth pinion, which mate with the two 4 th gears ..
You can also just make the installation of two 8 tooth pinions, they will give more strength to your crawler ..
I was very lucky to find this war tank used ($ 6.00), with two 34x10 and two motor 280.
I do not recall if the two 8 tooth pinions, came from that war-tank .. []
#35
CA
hi, i want to get a new body for my nb.. but i dont know which one to get..
pickup? like toyota/ford/chevy/etc..?
suv? bronco/blazer/etc..?
or any rockcrawler looking body..?
i also need help finding a website that sells either bodys..
soo let me know what wesites are good for buying new bodys..
thanks!
thanks!
#36
You can find bodies at most any hobby shop.
I usually get mine cheap from thrift stores,flea market,& yard sales
I have a few bodies not being used.....what exactly are you looking for???
#43
This small addition, it gives a very good look ..
It begins to resemble YELLOW-CRAWLER .. Just an idea ..
Keep up the good work ..[sm=thumbup.gif]
#44
CA
thanks.
how did you make the hard top for the yellow crawler?
and what did you use to take the stickers off? i used goof off and it started to remove the paint also...
#46
ORIGINAL: nbcrawler
thanks.
thanks.
On YELLOW-CRAWLER, everything that appears on the yellow paint has been painted with a small brush ..
For the hard top, I lowered the windshield, and I built the hard top, with plastic (DVD COVER) ..
The roll cage inside, is made with thick, plastic hangers .. [sm=thumbup.gif]
When I need a sticker, I cut from magazines, and I stick with glue made for plastic (below and above) ....
...or, I stick to real sticker ..
My crawler BLACK FLY .. before YELLOW-CRAWLER ...
#47
ORIGINAL: nbcrawler
HERES AN UPDATE..
THINKING ABOUT PAINTING IT. ANY SUGGESTIONS?
HERE IT IS.
HERES AN UPDATE..
HERE IT IS.
((((( GGGRREAT CCCRRRAAWLER ))))))[X(][X(]
