(( MODS on POLARIS-LIBERTY 800 VES )) TEXX
#76
RE: (( MODS on POLARIS-LIBERTY 800 VES )) TEXX
Thank rebuilder for the comment ..
It is true that the front suspension works very well ..
I am lucky to have had in my Possession, two springs (which come from another rc / INTRUDER toy, buy as spare / parts).
BIG-crawler has a system ESC FUTABA ,
The price for the kit FUTABA was very reasonable (( Tower's Low Price $84.99 .. $125.00 CANADA ))
(( I believe that this item, no longer sold in kit form.))
This system works very well ..
I installed in POLARIS..
1 stock JEEP motor 351 and electronic system BIG-CRAWLER/JEEP 1/6 NEWBRIGHT/351 MOTOR ....
+ Stock servo JEEP 1/6 .... It works very well ..
Plastic bag ... for water ...
But you are right, an ESC system is really the best .. And I could install a bigger motor ..
Shopping on ebay is good, but transportation to QUEBEC.QUEBEC CITY, is really quite expensive. I'll wait a bit ..[]
#77
sorry for my late reply, i have made a youtube video on the suspension http://www.youtube.com/watch?v=MBr-AEedXj8
#78
flimwad .. WOW [X(][X(] Goog video ..
Very good work on your suspension POLARIS ..
Thank for the video ..
#82
also texx, if you don't mind, would it be okay if i just put mods on your thread? i probably wont do much to and im kind of new to this whole forum thing
#84
ORIGINAL: flimwad
#85
flimwad ..
But it might be preferable, as you would your personal thread .. ?
Click on ((new post))
Do not forget the title of your thread .. Top of page ..
#87
On the first page .Toy-Grade RC Products ....in our forum ..at left.. top of the page.
NEW POST ..
All Forums >>
NEW POST ..
All Forums >>
#88
this is the thread i started http://www.rcuniverse.com/forum/m_93...tm.htm#9375572
#89
flimwad .. Cool thread ..[sm=thumbup.gif]
Small video .... My POLARIS
[youtube]http://www.youtube.com/watch?v=RbxIeOmb-PY[/youtube]
#91
On my video, there are many footprints in the snow, and it is in these footsteps, my POLARIS fell. []
The weight driver is not excessive, but l, remove, would certainly be good for the CG.[8D]
The place is where the second battery gives no chance for CG ..
I will find solutions to these probem..
Thank for the comments ..
PS ...
Separate me from my driver, I would grieve.[][]
PS ...
#92
My Polaris is my taste for now ..
An ESC system would be welcome, and a bigger motor, but I'll wait a bit .[].
I made major mods on my Polaris, with the means I possessed, and his behavior on the snow is fair .[sm=thumbup.gif]
I'm going to tour in flea markets and tried to find a RC/TOY, interesting ..
At this point, I find my POLARIS, $ 15.00.
Here are the mods made to my POLARIS ..
1 .. stock motor change for, 351 Newbright 1 / 6 Jeep.
2 .. change stock electrical panel, for, electrical panel Jeep 1 / 6 + quench it
3 .. change stock servo for, servo Jeep 1 / 6 (automatic return to center)
4 .. stretch belt..(( NEYOU86..MODS ))
5 .. install new spring/shock .. from a INTRUDER rc-radio-shack
6 .. install a second battery in parallel (between the legs of the driver)
7 .. install a security bar for the switch (on-off)
8 .. install (8) metal rods on the roll of training,..(( NEYOU86..MODS ))
9 .. install cooling-plate on motor..
10. Drill ventilation hatch on the cabin .. for cooling / motor.
..... and everything is proportional speed ..[8D]
#94
ORIGINAL: neyou86
hey texx happy new year. congrats on being on the 15 most active threads
Thanks .. for the information ..
I'll take great care of my POLARIS .. And if I can do some mods to improve its performance, I will surely ..
I will follow the new thread (snowmobiles) and keep all the good advice in my files ..
#95
MN
texx i got a good and easy mod for you. make wear bars in the skis. i did it and it has made my skis last alot longer and it turns better on ice. drill a hole in the ski then insert a wire through the hole then drill another hole and insert the piece of wire in that hole too.
this is what one looks like on a real snowmobile. http://www.bcnorth.ca/magazine/pages...ce/JohnSki.jpg
it is the metal bar in the center of the ski
if u need any help or pictures let me know
#96
YES .. This is a very good mod ..
Thank NEYOU86 for the pic ..
I am trying to use a small rod of metal / chrome ..
I'll do this mod .. maybe on my ski parts for inside the house ..
Thank .. NEYOU86 ..
2 small video ..
But my camera, was in position (macro) then the image is slightly blurred ..
The running time is approximately 25 minutes, with 2 battery installed in parallel. The temperature is very cold ..
Directly into the hole ...
[youtube]http://www.youtube.com/watch?v=RYrS1M2Y6pU[/youtube]
Cool run ...
[youtube]http://www.youtube.com/watch?v=gdUmSq_Ndkg[/youtube]
I try to make a video with a good image ..
They announced the milder weather in the coming days ..
Thank .. NEYOU86 ..
2 small video ..
Cool run ...
#97
HELLO ..
(( They are no big mods, but do not do, surely bring problems ))
To prevent overheating of the motor, I reinstall the cooling-plate on the motor, and I also cut a ventilation openings on the cab.
This will certainly help ..
And I install a stop arm on the switch panel Electric ..
This will prevent the switch to accidentally put in the position (on).
#98
HELLO ..
I have 2 small video ..
The belt does not slip, the servo works very well .. the shock are OK ..
The motor and the battery should be improved ..[sm=thumbup.gif]
This land is full of trap snowmobile hi hi hi[8D]
http://www.youtube.com/watch?v=xSp1PiPWI3Q
http://www.youtube.com/watch?v=VG5F4B8MhnU
#99
MN
texx, does your snowmoible have plenty of power? it looks like it does. you can put a larger pinion on your motor to get it a bit faster
#100
neyou86 ..
I install a pinion 8 tooth ..
The stock pinion had 12 tooth .. [X(]
10 or 12 tooth would be good, without losing too much power ?
PS...
The POLARIS, reverses itself quite easily ..
I think that the shock is too soft (replace the spring, with little stiffer spring, might be good) and the second battery is placed too high .. I think ..
PS...
