All hardened steel gears for t-maxx 2.5 tranny
http://www.robinsonracing.com/catalog/tmaxx25.html
RRP or anyone else does not have hardened steel forward and reverse (when using both together) output gears for the 2.5 Transmission.
You can upgrade the top (input shaft) gears and the middle (primary shaft) gears but the bottom (output shaft) gears will be the weak link.
If you convert to forward only you can upgrade the forward output gear to hardened steel but reverse must be removed to do so.
I and many others run BB engines with much more torque than a 3.3 with the black 2.5 transmission with the forward only conversion with little problems.
With reverse and a 3.3, if you don’t beat it too hard or set the slipper too tight or land jumps while on throttle you could get anywhere from 1 tank to many gallons of fuel before something inside the tranny fails. It depends a lot on a persons driving style and how tight you run the slipper clutch.
Russ
I have a highly modded MERV its fun but not as fun as the 1/10revo , i converted my 2.5maxx and soon found how week the plastic gears were in the tranny and that was only on 3s personally i think the 2.5maxx was the worse kit ive ever owned even with the 3.3 in it i killed the ring gears in the diffs and the stock axles are pitiful even with the slipper set right lol its just week. if you were to get a 3.3maxx roller you be lightyears ahead of the 2.5 .
