Pull-Start Eliminator
NC
I was running my freshly tuned Rustler w/O.S. .15 and was havin a blast (still pulling front tires off the ground at WOT). Then I decided to take a break of that after about 1/4 gallon of fuel, and wanted to run my T-Maxx around. I've got the Fantom FR18 with the Traxxas 2.5 pull start. I noticed that it has been slipping a lot lately and I cannot get it started because of this. I still tried to at least get it started and tugged on it for a while, then the stupid string got locked at full-pull. So now I've got about 1 1/2 feet of pullstart rope just hanging out of my truck. I'm probably gonna go figure out how to fix this (notice I said FIGURE OUT HOW) so I can cruise tomorrow. Then I saw the pull start eliminator on www.neweramodels.com and thought that would be pretty cool. I was just wondering what all you would need for it to work? Here's a link to the pull start thing-[link=http://www.neweramodels.com/cgi-bin/item.cgi?session_id=joktmapybpaqpjgofbgwudlgwagkuv fe&part_id=359]do you know which size I would need? 6mm or 8mm[/link] Like I said, what all would I need for something like this to work on a Fantom FR18?
Banned
My Feedback: (-1)
RE: Pull-Start Eliminator
Pull it a few times quickly. repeat that and it will go back in. It just seem to take forever,somtimes it goes back in easilly. But it will retract.
-Dallas
-Dallas
NC
How do you turn the one-way bearing with a drill? That link that I showed was the thing, but I'm sure there are other parts that I will need for it to work. What are they?
Banned
Listen i want a cheaper way?Take and put a lil bit of gasket sealent in the one way bearing,Yamaha Gasket sealent is what I used,Bolt her back up and there u go.It worked good for m .15
