revo wheelie
TN
revo wheelie
ok ive been adjusting the lsn on my revo and i still cant get the front wheels off the ground.Can anyone post there needle settings so maybe i can get a wheelie.I used the search and couldnt find the answer.Thanks in advance.i also stiffend the shocks to make it easier to wheelie.
RE: revo wheelie
you shouldnt have to really lean it out to wheelie, just put more pretention in the front shocks and less in the rear. i would set the engines needles to the way its instructed in the manuals. if you overheat the engine to often, you will destroy it.
RE: revo wheelie
Someone else's needle settings could be way different than what you're running....Altitude, temperature, and humidity all come in to play when tuning a nitro powered engine. I havent even got the chance to start my Revo yet.....are you guys having trouble with them getting hot like the Tmaxx?
RE: revo wheelie
The truck will not wheelie bone stock. If you like wheelieing, run stiffer springs all the way around with thicker oil. You can also use a smaller clutchbell and/or lighter tires ( bowties, road rages, etc).
