SHIFTING PROBS
NS, CANADA
SHIFTING PROBS
hi, i've got a t maxx with a mach 26 conversion, ever since i put the big block in i've lost 2nd gear, the engine just winds out in first, i tried to adjust the shift points as it describes in the manul, with no luck. I read in a similar post about bottoming out the ajustment screw and turning it 7 turns out to get back to stock settings, i tried this and it shifted in to second gear twice, then it went back to only having first gear[:@], I've upgraded everything on this truck,[>:] except the tranny which its workings are a mystery to me. Any suggestions would be helpfull
RE: SHIFTING PROBS
tell you what i got a mach .26 i noticed it sounded like it wasn't going in to 2nd gear this is because there is hardly any drop in revs from the engine when it shifts cause its got so much power, but if you do notice its going realy slow toped out then some thing else much be wrong.
