Need Help REVO Won't start
SC
Bought a REVO the other day from the local hobby shop. I did the breaking in process yesterday and completed the after run procedure last night. Today for some reason the truck won't start. I have cleared the engine after it flooded while attempting to start it several times and still the starter motor just spins. All batteries are fully charged and I even put in a new glow plug. I am running 20% fuel if that makes a difference. Any help would be appreciated as to where to look. After having so much fun yesterday it is killing me that this thing won't start up.
Xman
Xman
RE: Need Help REVO Won't start
is the flywheel spinning when you crank the e-z start?
are you using a glow starter, or the wire from the e-z start?
if you are using the e-z start wire, trace the wires from the engine to the connector,and see if they are damaged.
SC
Engine is spinning. I am using the ez start system as I don't have a glow starter. Unfortunately after reading another post while searching I removed the HSN and cleaned it but when I was replacing it I over tightened it and it broke off. So tomorrow I will be going to the LHS and buying a glow starter temp guage and carburetor body. Hopefully they are in stock cause this waiting is killing me. Maybe I need to buy a spare so that when one is down I can still be out driving.
if u are useing the ez strart make sure both lights comeo n when u hit the button if the glow plug one doest check ur ground and then your lead wire ...
