Red/Green Flash After Setting Optidrive(XS3)
VA
Hey everyone, I've got a question about setting up my Radio with the Optidrive. I am usig a JR XS3 setup and installed the RX, Setup all my TX settings(servo dir,epa,rev,etc), and I turn em both on, hold down the button till it blinks twice, let it go. Hold full throttle and then when I get three blinks, I let it go. Then I have my blue light and a Red/Green intermittent flash. Whats up with that? Everything is turning, throttle brake, Rev working etc, but I have the intermittent Red/green flash.
VA
RE: Red/Green Flash After Setting Optidrive(XS3)
Uhh yeah, forgot to mention that had been done. Also, stock servos still if that makes a difference. I have been looking at a couple threads on teh Traxxas board and it seems that there's a need for some type of different y harness deal when using the XS3 with stock servos and the Optidrive? I'm gettin ready to unhook this BS all togther!
PA
Buy a "Y" harness and plug the throttle servo and the battery throught the Y ine the receiver. This should take care of the problem. I have the same setup. If you change the throttle servo to a JR servo, that opens another can of worms where you need to purchase a servo reversing harness to get things to operate properly. (Changing the servo mode from normal to reverse in the transmitter will not work).
Hope this helps,
Todd
Hope this helps,
Todd
