Traxxas EVX Speed Control Marine Villain EX
NY
Why wont the Traxxas EVX Speed Control Marine work with an E-maxx.... what is different??? and it would be better sealed... therefore water resistant better!
NY
RE: Traxxas EVX Speed Control Marine Villain EX
i was thinking the same thing getting the marine version of the evx for better water protection . how do you know it wouldnt work ?
AL
the proble is that it has a totally diffrent cooling systen there for you would have to make a water pump to go threw the coolingthing on top. if you ddont u will fry it cause it will get to hot.
MN
as hotchi said, it has a different cooling system. you will need to get the heatsinks from a normal EVX, and mount them to the marine one. Just take off the water cooling element, and slide on the heatsinks. also, the marine one has like only 30% reverse i think
AL
thats all in programing is it not? i think the water proffing goes away when you take of the gray plastic water readiator thing
