quick emaxx question about batt. and motor
CA
hi, is the batteries to the emaxx seperate for each motor or are they connected as one full power source? what im trying to say is ...since there are 2 motors and 2 batteries..is one battery supplying one motor ...or is it just 2 batteries for 2 motors.
im asking this becuase some ppl are telling me two 7 cells for the emaxx is fun but can fry the titans...so im thinking..what if i i put one 7 cell and the other a 6 cell...that should be ok. but if it s one battery to one motor...then i cant do this.
AL
RE: quick emaxx question about batt. and motor
no the esc changes it from two battery souces into one. it basiclly has a v connector but it is inside esc case. and u can run the 15.6 voltss cause that betwewen the 7 cells and the 6 cells. that is what my friend has and it works perfect. just enough power to not fry stuff. just buy 2 fusion 7 cells and two fusin 6 cells that way u can charge them while u are runin the others
CA
can anyone second that, or does anyone disagree?? i just dont want to ruin things..just making sure hotchi.
thanks
thanks
Yes, you can do that. The batteries are really in one big series loop although just by looking at the connections it doesn't appear that way..
mix and match no prefrence on it as it is a 14v system. As a clod buster owner I remember 2 6 cell batts, and a special pkg. I doubled the 2 six cells and ran it with the special pkg and doubled my speed and run time
so the same can be done to the mas dble the batts as a 6 or 7 cell. and run it in a series x 2 and you'll dble the run time but have to charge 4 batt's.
MN
ORIGINAL: fishycomics
