How much faster is an OS.18 CVR than a Pro15?
ON, CANADA
I'm going to be getting a new engine soon for my TMAXX and was wondering if it would be worth it to get a .18CVR. I mean, will it be a lot faster than a Pro15? AND will it pull wheelies? I'd like to get the .18TM but I don't think I'd be able to afford it. I've got a bunch of other stuff to fix for race season...
Another quick question: if I get the .18CVR-X with slide carb and standard crank, I'll need to get the slide carb bellcrank for the TMAXX 2.5 and I would have to grind the crank right?
thanks in advance
thanks in advance
AL
RE: How much faster is an OS.18 CVR than a Pro15?
dont get the slide one get the stock linkage.one. the get the 18 cvrxs cause it is ready to go in stock 1.5 maxx . it will flip ur truck up on its lid during brake in. it has mad power compared to the pro 15.
Yep the os 18 cv-r is off the hook you wont be disapointed. The 2.5 has 60% more power than the pro.15 and the o.s will walk all over any 2.5 maxx.
ON, CANADA
wicked! that's what I want to hear!
so I need to go with the one with a rotary carb and short crankshaft? Can I get one with the short crank and slide carb. I just like slide carbs better. I always have a problem getting my rotary carbs to go to full throttle. I never seem to have enough travel on my servos...
My epic .18 wasnt that much FASTER per say. but had easly twice as much power/torque. Meaning wheelies, mad curb climbs, etc.
you WONT be disaponted.
(like they said go with the rotary carb as its a direct replacement for the pro.15)
AL
is your pro 15 worn out? cause that is y i say keep the ratry linkgge carb cause u could swithc engines in less time if u were like gonna go somwere u did not want to risk damaging ur 18
MI
just a quick question. when you guys are talking about the pro 15, are you talking about the stock engine on the 1st gen tmaxx? I just picked one up and want to drop a good but easy to use engine for a newb (ME).
Thx
Thx
